harness bar
Discussion in 'Long Travel Suspension' started by Mb471, Aug 22, 2020.
  1. Aug 22, 2020 at 6:06 PM
    Mb471
    Mb471 [OP] Well-Known Member
    Bay Area, ca
    17 DCLB
    being that the only people that would look at this is more than likely the pre runner guys on here i figured it was best to post my question in the long travel department. So, i need a harness bar for my truck so i can put the PRP seats and harnesses in the truck. Does anyone know of some one that makes a harness bar preferably bolt in for third gens
  2. Aug 23, 2020 at 8:40 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Don’t run harnesses without a cage.
  3. Aug 24, 2020 at 8:33 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I whole heartedly second this!
  4. Aug 25, 2020 at 6:54 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Harnesses without a cage is bad juju - you become the "D" pillar when the A/B/C pillars start folding in a cage. Your stock seats will collapse with you in a roll over, rather than hold you up as the pillar.
    Harness bars should be part of a roll cage build.
    Don't cage a daily driver. You will regret it.
  5. Aug 26, 2020 at 8:14 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Schroth Racing makes a line of DOT legal harnesses, half of which buckle into or bolt into existing seat belt buckles or bolts.
    https://www.schrothracing.com/products/tuning-Harnesses
    I'm curious to try out their Quick Fit model before I cage my truck and it no longer is a DD.
    https://www.schrothracing.com/item/schroth-quickfit/tuning-Harnesses
    They don't list the Tacoma as a vehicle in the drop-down, but I don't see why they wouldn't (maybe belt length). Tacomas have all the correct buckles and bolts to use the Quick Fit. I've tried to contact them with these questions without success.
    Update if you go this route!
    Mb471[OP] likes this.
