Harness choice 23 TRD OR DC
Discussion in 'FBC Harness Solutions' started by GaMGMTaco, Nov 25, 2024.
  1. Nov 25, 2024 at 10:07 AM
    GaMGMTaco
    GaMGMTaco [OP] Well-Known Member
    Billy
    NE Georgia
    23’ MGM TRD OR DCSB 4x4
    Want to make sure before I order that I am choosing the correct harness. I currently have raptor lights wired via an add a fuse setup. Will I need the basic OEM conversion or the conversion w/ grille lights? Not sure if the current setup needs the be replaced for this conversion. Also, will after market sequential turn signals cause any issues?
  2. Nov 25, 2024 at 11:44 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    You are going to replace halogen headlights with OEM LED headlights?
  3. Nov 25, 2024 at 11:46 AM
    GaMGMTaco
    Billy
    NE Georgia
    Yes sir. Stock halogen with DRL to OEM Pros.
  4. Nov 25, 2024 at 11:51 AM
    daveeasa
    David
    PNW
    Then I would recommend the "with grille lights" harness for your grille lights.
    If you want/plan for backlight on ss3 fog lights now or in the future, you might want the "dual grille" option but for grille lights only a single grille, driver side (default) makes the most sense and is what I do on my own truck (bought ss3's before the backlight option).
    Sound good? Further q's?
  5. Nov 25, 2024 at 12:01 PM
    GaMGMTaco
    Billy
    NE Georgia
    Last questions, your harness will replace the add a fuse? My grille lights currently only come on with the headlights, will that change?
  6. Nov 25, 2024 at 1:05 PM
    daveeasa
    David
    PNW
    Grille lights will be on anytime the stalk is not set to off.
    GaMGMTaco[OP] likes this.
  7. Nov 25, 2024 at 1:41 PM
    GaMGMTaco
    Billy
    NE Georgia
    Ordered. Thank you for the quick response and help. Looking forward to getting the harness. Have great Thanksgiving.
    daveeasa likes this.
  8. Nov 25, 2024 at 6:29 PM
    deansenzo
    deansenzo New Member
    is there a conversion harness available for the sr5 to led oem lamps having hard time finding any
  9. Nov 25, 2024 at 6:30 PM
    daveeasa
    David
    PNW
  10. Nov 25, 2024 at 6:44 PM
    deansenzo
    ok thanks will the 20-23 trd pro led lights fit on a 2019 sr5
  11. Nov 25, 2024 at 7:01 PM
    daveeasa
    David
    PNW
    Si
  12. Nov 26, 2024 at 8:52 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  13. Dec 7, 2024 at 10:01 AM
    GaMGMTaco
    Billy
    NE Georgia
    Dave. I can’t thank you enough for the harness. Got my LEDs installed today. Your harness is well made, easy to use, and made this a true plug-n-play install. For anyone thinking about this harness, just buy it. Also, if your lights aren’t working properly after install, make sure you’ve plugged in the connections until you hear the “click”.;)
