Harness for Diode Dynamics ss3
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larsanderson10, Oct 12, 2023.
  1. Oct 12, 2023 at 1:57 PM
    Larsanderson10
    Larsanderson10 [OP] Active Member
    Lars
    U.P. Michigan
    2012 2.7L 5-spd Manual Tacoma
    I'm getting diode dynamics ss3 pro pods, without the backlight. I'm putting them in as fog lights, but since I don't have stock fogs, I need a wiring harness. I want to put an OEM style switch in, and I've been told I need a harness with a relay for that. The DD dual output harness with a relay is backordered 6-8 weeks. Is there another harness I could buy? I know very little about wiring, and don't know what to buy. It looks like the ss3 kit comes with Deutsch 2-pin connectors, so is there a dual output harness with those connectors and a relay that I could 'plug 'n play'?
  2. Oct 12, 2023 at 2:10 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    You could go to your local automotive store, normally sell a fog relay kit harness and you all you need to do is buy the switch. Or you could buy a relay and build your own harness. :)
  3. Oct 12, 2023 at 2:12 PM
    Larsanderson10
    Lars
    U.P. Michigan
  4. Oct 12, 2023 at 2:13 PM
    TegoTaco
    Ontario, Canada
    Looks like it. :) same plugs as the DD’s.
    Larsanderson10[OP] likes this.
  5. Oct 12, 2023 at 8:31 PM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Amazon h11 to light bar harness
