Harsh downshift/Stall/RPM drop
Discussion in 'Technical Chat' started by RugbyTaco, Aug 3, 2011.
  1. Aug 3, 2011 at 9:30 AM
    RugbyTaco
    RugbyTaco [OP] Rhum.
    Paul
    Chicago
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    Ok so after i installed my rear AAL I got a lil bit of the take off shudder, so shims are on the way. After a week or so the tranny is downshifting really harshly when i let off the gas and sometimes while at a red light. It feels like the trans is stuck sometimes, especially after it downshifts. Its even stalled twice. I also have an URD MAF, but ive had that for a while now. At idle the RPMs are ~500-700 RPM. I had the pedal chop but cant say for certain if they did the trans flash, as they did the pedal chop while they did the rear leaf tsb. I also just installed a DDM HID kit, so they battery was unplugged but that was Monday morning.
    Suggestions? I wana see if it goes away or if i can fix it before i go to the dealership.
  2. Aug 3, 2011 at 11:01 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    A stalling automatic usually means there is generally a possible major problem. Wish I could help, sounds like your truck just wants to take a major shit and clear it's system out lol..mine does that hear and there. Damn bitch.;)
  3. Aug 3, 2011 at 11:09 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    If you're under warranty, take it back. Could be as simple as bad gas or, as mentioned above, something much more serious. An automatic in a 1 year old truck shouldn't stall the motor out under any circumstances.
  4. Aug 3, 2011 at 11:45 AM
    RugbyTaco
    Paul
    Chicago
    I know that after a MAF is installed and the ECU reset(battery disconnect), the engine may stall once and it did but 3 days after. It dosen't downshift real hard every time, it seems that the fluccuations in the RPMs might be more of the culprit, but im not sure. anybody else have something similar and have the Tranny TSB?
  5. Aug 6, 2011 at 10:01 AM
    RugbyTaco
    Paul
    Chicago
    Ok so I ran some seafoam in the gas tank and it seems to have helped. Odd for a truck that has under 15K to have had dirty injectors?! Still want to try CB drop and or axle shims. If it stalls or seizes up again im goin to the dealership
  6. Sep 28, 2011 at 12:50 PM
    RugbyTaco
    Paul
    Chicago
    UPDATE!!! SO for a while this problem stoppped. Then today it happened again. The truck completely stalled and stopped running while driving. I pulled over and restarted it only to have it shut off about a minute later. I started it and it would settle into its idle and then shut off. This happened about 5 times in a row. The 6th time I quickly threw the truck into drive and went. Once I got home I out the car in drive and sat there with my foot on the brake just to see what would happen. Nothing happened in drive but once i put the car in park, it settled into its idle again and the rpms dropped and the car shut off. I brought the truck to my dealership and they just called me saying that they were able to create the problem but the computer isnt registering any codes or errors. They have a call into Toyota Tech and will hopefully have some more info tomorrow.
    Anybody have something similar happen? Could this be fro the URD MAF? This dosent happen all the time so I wouldn't think so. Maybe my drivetrain angles are off, but again this would happen all the time? Any input would be awesome.
  7. Sep 28, 2011 at 12:54 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i wouldnt do anything else cause. have it towed to the dealership, have them cover the charges
  8. Sep 28, 2011 at 12:58 PM
    RugbyTaco
    Paul
    Chicago
    Its already at the dealership and they are keeping it overnight. I was able to drive it there. Im still under warranty and i have the platinum protection. It also feels like the trans is sticky, like it dosent want to shift into the next gear. That is just what it feels like to me, along with everything else.
  9. Sep 28, 2011 at 1:05 PM
    RugbyTaco
    Paul
    Chicago
    I thought about that but, if it was the MAF wouldnt this consistently happen? At the very least the sea foam cleaned the injectors...
  10. Sep 28, 2011 at 1:10 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Maybe I missed another thread but, when did this all start happening?
    What mods, or lack thereof, did you have when you last remember the truck running perfectly?
    Something has to have changed to cause this to happen given how new your truck is.
    Fink
  11. Sep 28, 2011 at 1:10 PM
    RugbyTaco
    Paul
    Chicago
    Ah good point. When i get the truck back, i will pull the MAF. It just happens so randomly, thats whats got me more confused. Until today this hasn't happened in almost 2 months
  12. Sep 28, 2011 at 1:13 PM
    RugbyTaco
    Paul
    Chicago
    This first happened almost 2 months ago. The only mods are my lift and the URD MAF.
    whippersnapper: Since i spliced into the ecu wires, would i just have to solder them back together?
  13. Sep 28, 2011 at 1:16 PM
    Fink
    Orlando, FL
    I'm assuming you mean the URD MAF Sensor Calibrator, right? Do you have a cat-back exhaust or a CAI or anything?
    I'm just trying to figure out why you got the URD MAF Calibrator to begin with to better assess the situation.
    Fink
  14. Sep 28, 2011 at 1:17 PM
    RugbyTaco
    Paul
    Chicago
    Theres the plug for the usb, but for the install i didnt use the harness, just spliced into the wires in the diagram i got from gadget.
  15. Sep 28, 2011 at 1:17 PM
    Fink
    Orlando, FL
    I was wondering this too, but looking on URD's site, it doesn't look like it does. I imagine the wiring diagram just has them tapping directly into the ECU.
    Fink
  16. Sep 28, 2011 at 1:18 PM
    RugbyTaco
    Paul
    Chicago
    Yeah, its the URD MAF. I have a wicked flow 13" on stock piping and an AFE pro dry. I got a good deal on it plus im planning on headers as well
  17. Sep 28, 2011 at 1:19 PM
    RugbyTaco
    Paul
    Chicago
    Lame? How so?
  18. Sep 28, 2011 at 1:19 PM
    Fink
    Orlando, FL
    If that's the case, I would contact URD/Gadget and run this by them. Those guys are awesome and really know their stuff. They may be able to provide more insight on it before you go cutting and soldering.
    Fink
  19. Sep 28, 2011 at 1:20 PM
    Fink
    Orlando, FL
    If it had a connector, you could easily remove it to test how it acts without it...now you are stuck cutting and resoldering if you need to remove it.
    Fink
  20. Sep 28, 2011 at 1:21 PM
    RugbyTaco
    Paul
    Chicago
    ^ Yeah i didnt know they had the harness until after i did the install. But I will definetly contact urd/gadget, thanks
