Harsh ride from rear end over cattle guards and expansion joints, solution?
Discussion in 'Suspension' started by rockhopjohn, Dec 23, 2016.
  1. Dec 23, 2016 at 1:28 PM
    rockhopjohn
    rockhopjohn [OP] Well-Known Member
    ID, MT, ND, I'm a transient
    2013 Tacoma T|X Baja
    I have a 2013 Baja TX running stock springs and dampers and 81k miles on the clock. I do a lot of high speed off road driving (50-70 MPH) on dirt roads in the oil field and I find that when I hit bumps like cattle guards, or expansion cracks in bridges, where both rear tires hit at the same time, I get a very harsh bump from the rear end. I have a topper and tend to always have 300-400 lbs of stuff in the truck, so right after I got it, I installed a set of Firestone Ride-Rite air bags, and I usually run 5 lbs if of pressure in them. They do a good job of dealing with the sag in the rear end, but I am wonder if they are contributing to this harshness.
    Any suggestions on solutions? I need the topper, and I have to carry this weight with me all the time, so I need something that will let me keep up the 60-70 MPH speed, but not hammer me every time I hit a cattle guard. Do I need upgrade rear leafs, hydraulic bump stops in the rear, both? Suggestions would be greatly appreciated.
  2. Dec 23, 2016 at 1:33 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Well I can't help you alot but I do know those ride rites aren't supposed to be used while off roading it's a good way to blow up those bags. other than that I don't have advice for you but maybe put some kings in the back smooth body kings would work alot better than stock
  3. Dec 23, 2016 at 1:35 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    With that weight you should upgrade to Dakars and better shocks
  4. Dec 24, 2016 at 7:04 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    New leafs and shocks.
  5. Dec 24, 2016 at 7:09 AM
    rockhopjohn
    So are Dakars the only real option for solving this problem that will give me around 2" of lift over the stock off-road? The Bilstein 5160's that came on the Baja are pretty decent shock and still appear to be in decent shape.
