Harsh ride quality from Old Man Emu lift
Discussion in 'Suspension' started by Dr.TunaTaco, May 17, 2013.
  1. May 17, 2013 at 7:49 AM
    Dr.TunaTaco
    Dr.TunaTaco [OP] Member
    Colorado
    txpro
    I have a 2012 TxPro double cab. Got the lift installed on my truck about 10,000 miles ago and figured it would settle down after that but still seems to be really harsh ride was wondering if any of guys would know of a better strut set up to improve ride and overall performance
    truck has Old Man Emu 4" lift springs and struts front and Old Man Emu struts with Dakar leaf springs in the rear. no control arms yet but will soon.
    Anyone have any suggestions or feed back?
  2. May 17, 2013 at 8:06 AM
    TicoTRD
    TicoTRD Well-Known Member
    Tico
    410
    '11 MGM SR5 AC
    OME makes a 4" lift?
  3. May 17, 2013 at 8:10 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What springs did you get, 885 or 886?
    Either way, it will ride stiffer than stock... OME coils have a higher spring rate than stock and you're replacing a 3 leaf pack with a 7 leaf pack, it will ride stiffer. What load range are your tires?
  4. May 17, 2013 at 8:13 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    X2
  5. May 17, 2013 at 8:16 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    Manitoba
    08 TRD
    886 w/o armour?
  6. May 17, 2013 at 8:16 AM
    CowboyTaco
    CowboyTaco Well-Known Member
    North Texas
    11 TRD Sport
    Ironman Lift w/ Dakar Leaf Pack, ARB Front Bumper, Relentless Rock Sliders, AllPro IFS Skid Plate, WeatherTech Floor Liners.
    which springs did you get?
    I'm not familiar with a 4" OME lift. I'm guessing you got the 886x springs and don't have any extra weight up front. Also, that much lift will throw out your alignment.
    add weight up front or get softer springs and get the light racing upper control arms.
  7. May 17, 2013 at 8:17 AM
    OZ-T
    Peter North
    British Columbia
    886 + top plate spacer ?
  8. May 17, 2013 at 8:19 AM
    CowboyTaco
    North Texas
    11 TRD Sport
    that's what my money is on.
  9. May 17, 2013 at 8:20 AM
    TicoTRD
    Tico
    410
    '11 MGM SR5 AC
    yea thats what im thinking. and yea all of the upgraded suspension is going to be stiffer than stock, but thats what you gotta do.
    you gotta risk it for the biscuit...:D
  10. May 17, 2013 at 8:23 AM
    Hairy Taco
    Manitoba
    08 TRD
    Need to provide more information OP.
  11. May 17, 2013 at 8:25 AM
    TicoTRD
    Tico
    410
    '11 MGM SR5 AC
    ^this!
  12. May 17, 2013 at 9:07 AM
    OZ-T
    Peter North
    British Columbia
    OP , do you have a 4x4 ?
  13. May 17, 2013 at 9:09 AM
    CowboyTaco
    North Texas
    11 TRD Sport
  14. May 17, 2013 at 9:40 AM
    Dr.TunaTaco
    Colorado
    txpro
    I have the 885 with no armor and im running the goodyear duratrac 285 75 16 with d load range the 8 ply. have no top spacers in front
  15. May 17, 2013 at 9:45 AM
    Dr.TunaTaco
    Colorado
    txpro
    its oem 3" * lift
  16. May 17, 2013 at 9:52 AM
    OZ-T
    Peter North
    British Columbia
    If you're unhappy with the stiffness of that set up maybe ICONs may offer a smoother ride
  17. May 17, 2013 at 9:52 AM
    Hairy Taco
    Manitoba
    08 TRD
    This is a common lift around TW. I have only ever heard praise thrown at it. I run what should be a stiffer suspension and find it quite smooth and preferable to stock. Did you just switch from a P rated to a D rated LT as well? This in combination with high tire psi could be a problem.
  18. May 17, 2013 at 9:58 AM
    Dr.TunaTaco
    Colorado
    txpro
    I run 37 psi In the tires and I do like the ride its seems super rough over sharp dips or pot holes. does ride better then stock other than barely wandering on the highway which I know the total Kaos upper control arms will fix. just seen a couple of guys rolling with the kings up front and fox rears and was wondering if that could be an option with my lift
  19. May 17, 2013 at 11:00 AM
    Pugga
    Massachusetts
    F-150 Mod
    You went with a higher spring rate than stock and D-rated tires for a light truck, it's going to ride stiffer... A rebuildable shock might make it feel a little better if you can get them setup properly for the way you drive but it'll be a lot more money than your OME setup.
    King and Fox products would be an option for your lift. A King or Fox coilover would replace your OME front coilover and you could run King or Fox rear shocks in place of the Nitrocharger rear shocks. It'll work, just depends on whether or not you have the coin to do it.
  20. May 17, 2013 at 11:07 AM
    Dr.TunaTaco
    Colorado
    txpro
    thanks for the info guys. do you think even running a little lower tire pressure would be alright. and what your opinion on upper and lower control arms
