harsh ride tsb
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awwmann, Oct 27, 2009.
  1. Oct 27, 2009 at 11:12 PM
    awwmann
    awwmann [OP] Well-Known Member
    pat
    staten island new york/ redbank nj
    2015 4x4 double cab trd sport
    bilstein 5100/ 265/70/17
    been to the dealer about 6 times to complain about the rear end bottoming out with any weight in it . was told there is nothing wrong with the truck thats how it suppose to be . showed the service manager a copy of the tsb told me it isnt for my truck a double cab trd sport ? so i called the 1800# spoke to someone today they took my info gave me an incident # and said someone should contact me in about 24 hours hope they go for it
  2. Oct 27, 2009 at 11:19 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Good luck.
  3. Oct 27, 2009 at 11:20 PM
    Spootypuff
    Spootypuff Well-Known Member
    Jacksonville, FL
    SWB Sport Double Cab SB 4x4
    Satoshi
    I have pretty much your same truck and got the tsb done about a month ago. You can definitely get it, just be persistent.
  4. Oct 28, 2009 at 5:20 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16's
    Are you still under warranty? If so raise hell thats what I did to get my TSB done. (I got mine done before Toyota would cover the 08's) Good luck man.
  5. Oct 28, 2009 at 9:44 AM
    awwmann
    pat
    yeah im still under warranty till the end of next week got 31000 miles on the truck and its coming up to 3 years
  6. Oct 28, 2009 at 10:00 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    good luck. i just got off the phone a few minutes ago with my dealership. he (javier) said to bring it in. i mentioned that my rig has 39000 miles and he said toyota warranties suspension for 60k miles, and if they determine that i need it, i am all "GO". if not, then i dont care. i just need to get a relatively decent load in the back. if i dont have issues, i am golden.
  7. Oct 29, 2009 at 1:15 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Why didn't you just point out where is states what vehicles are covered on the TSB??
    2005-2008 Tacoma Access and Double Cabs...Prerunners and 4x4....still under factory warranty 3yr/36k miles.
    Suspension TSB PDF (Revised): T-SB-0305-08 Rev 1.pdf
  8. Oct 29, 2009 at 1:20 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Read the TSB for yourself...it applies to 3yrs/36k miles only...it's on the bottom of page 2.
    APPLICABLE WARRANTY​
    • This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for
    36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
    • Warranty application is limited to correction of a problem based upon a customer’s specific​
    complaint.
    Also per the TSB, its based strictly on customer complaint, so you do not have to prove you have a problem or load x amount of weight or anything like that.
    But if your dealer gets approved to do it then good for you, just do your own research before you go.
    :thumbsup:
  9. Oct 29, 2009 at 11:46 AM
    aficianado
    back to bone stock.
    foxy...i did read that. just didnt want to correct my dealer rep. if he fixes it, homerun. if not, whatever..AAL
  10. Oct 30, 2009 at 4:07 AM
    FoxySandChick
    Kristin
    Henderson, NV
    You are the customer, you had the info, you should correct them or ask to speak to the General Manager or the shop foreman, the service writers do not always (or even most of the time) know what they are talking about.
  11. Oct 30, 2009 at 4:55 AM
    tanktodd
    tanktodd Well-Known Member
    Todd
    back on the right side of the bay, Ala
    08 Prerunner w/TRD Sport Pkg
    Limo tint in back w/ 20% on doors. Removed all badges. Stereo headunit, all new door speakers, 2 amps, and 10' sub...so far Black bullbar MotoMetals and 285/70/17 Duratracs. 3" OME springs in front and aal in back with tsb springs Black UWS tool box 5100's all around Plasti-dipped evo front end Fog light anytime mod OEM steps (for sale) HID fogs 55w 3000k HID heads 35 w 6000k "Cool white" dome & map lights
    I'm sitting outside service department about to get the tsb done on my 08 Prerunner. Just have to be persistant.
  12. Oct 30, 2009 at 7:56 AM
    RI06TACO
    RI06TACO Well-Known Member
    Jeff
    Rhode Island
    06 Tacoma Sport
    These troubles from the dealerships are crazy! I bought a used 06 sport certified last week, read about the tsb on here, loaded my atv in th eback, brought it to dealer, and complained...they are doing the tsb next week. That simple. I guess it all depends on where you take it. When I called th eguy he gave me no trouble, they did however have a claim person come in to inspect it before giving the authorization..Good luck guys
  13. Oct 30, 2009 at 8:06 AM
    sioux_hockey_guy
    sioux_hockey_guy Well-Known Member
    Bismarck, ND
    Black '08 TRD OR 2" Leveled
    Eibach front springs, Billstein 5100's set at .85" Rear blocks (1.5"?) w, TSB. To be replaced w/ AAL
    I'm getting my TSB done this morning. At first they weren't going to do it because I have a block lift in back which I kind of figured. I spoke with the Tech and said that the truck is worthless to me if I can't haul a load. I told him to just leave the Blocks off if they create a problem. He was good about it and is gonna try to put them back in. We'll see here in a few hours. Cedric Theel in Bismarck, ND is the dealership. I've had nothing but good experience there so far.
  14. Oct 30, 2009 at 8:11 AM
    bcsnave
    bcsnave Well-Known Member
    Wisconsin
    06 4x4
    I have a 2005 reg cab 4 cyl....it has a 3 leaf pack on it. It seems to be a bit low in the rear.
    Any suggestions.
    Bill
  15. Oct 30, 2009 at 8:43 AM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    What happened to the toyota dealers ?? Their service used to be so good years ago.
  16. Oct 30, 2009 at 8:54 AM
    bishtacova
    bishtacova Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    The stealerships got your money on the sale. There's no money or incentive in service anymore.
  17. Oct 30, 2009 at 10:20 AM
    aficianado
    back to bone stock.
    FOXY, are we speaking different languages? my truck is OUT of warranty. the TSB said, anything over 36k is SOL. i have almost 40k. the service advisor said the toyo suspension warranty is more than the 36k miles and he will cover my truck if it needs the TSB. if he is wrong, he is wrong in my favor...why would i argue? truck is with him right now for inspection...keep you guys posted.
  18. Oct 30, 2009 at 1:32 PM
    awwmann
    pat
    well they called me back today have to bring the truck in on tuesday to be inspected ill see what happens
  19. Oct 30, 2009 at 1:52 PM
    aficianado
    back to bone stock.
    denied!
    they did offer to cover parts, and i just pay for labor. i told them i will think about it. still around $500ish.
  20. Oct 31, 2009 at 1:19 AM
    FoxySandChick
    Kristin
    Henderson, NV
    My mistake...I mixed you up for being the OP :thumbsup:who is under warranty, had the TSB in front of him stating he is covered and let the service manager tell him he isn't covered.
    Add A Leaf is the same thing and much cheaper, do it yourself.
