Harsh shift to drive help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbarone1994, Apr 4, 2016.
  1. Apr 4, 2016 at 6:56 PM
    danbarone1994
    danbarone1994 [OP] Well-Known Member
    Daniel
    2019 Toyota Tacoma Gray TRD OR V6 double cab
    LED headlights, TRD PRO grill, Spacer kit 2 in lift front
    Anyone have any ideas? When I shift into drive occasionally I get a period where the truck doesn't shift but will shift into drive if I go to park and then drive also will slam into gear but I don't let it. Transmission control computer issue? Fluid levels are perfect no leaks. New filter only a few hundred miles and new fluid only about 50 miles on the fluid. Anyone have any ideas that may be the issue?
  2. Apr 4, 2016 at 6:58 PM
    Tacoma Mike
    Southern Maine
    Was it ok before someone "worked on it" ???
    Lester Lugnut likes this.
  3. Apr 5, 2016 at 5:12 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    This
  4. Apr 5, 2016 at 7:04 AM
    danbarone1994
    Daniel
    Yeah from my memory.
  5. Apr 5, 2016 at 7:27 AM
    Pigpen
    Dan
    Northwest Montana
    Sounds like you had a transmission flush and cleaned out the friction particles that were helping it shift properly. Bummer.
  6. Apr 7, 2016 at 7:33 AM
    danbarone1994
    Daniel
    no it was just a drain and fill and filter.
  7. Apr 7, 2016 at 7:38 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Could be low on fluid.
  8. Apr 7, 2016 at 7:40 AM
    Clearwater Bill
    Billy
    Largo Florida
    You say the fluid levels are perfect.
    I hope when you check it again (hot, in park, running IIRC) you find you are wrong.
  9. Apr 7, 2016 at 7:42 AM
    nh_yota
    Jeff
    Portsmouth, NH
    Yeah that's what I was getting at also, checking the level on an automatic transmission has to be done a specific way or you will get inaccurate readings.
  10. Apr 7, 2016 at 9:02 AM
    gearcruncher
    Canadain bumper technician
  11. Apr 7, 2016 at 10:01 AM
    danbarone1994
    Daniel
    How do you check fluid level? I think the shop that did it doesn't know how to check correctly... No dip stick...
  12. Apr 7, 2016 at 10:02 AM
    gearcruncher
    what transmission do you have ?
  13. Apr 7, 2016 at 10:03 AM
    danbarone1994
    Daniel
    Auto 5 Speed 05 tacoma
    gearcruncher likes this.
  14. Apr 7, 2016 at 10:06 AM
    gearcruncher
    Fixed my post at the top according to your transmission .
