Harsh vibration when slowly turning the wheel and moving
Discussion in 'Suspension' started by nighthawk87, Oct 16, 2010.
  1. Oct 16, 2010 at 11:00 PM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    I have a really harsh vibration in the steering wheel when I turn the wheel as I'm moving slowly from a stop. Mostly when backing out if a spot.
    Anyone know what this might be?
    I have a 2008 4x4 dc w/king rr set at 2.5", rear aal, 265/70/17 bfgs
  2. Oct 16, 2010 at 11:03 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    odd im ive noticed some serious vibrations almost bouncing up and down when in situations like you have described, although im a first gen id be interested in knowing as well
  3. Oct 17, 2010 at 4:38 AM
    zebra1550
    zebra1550 Well-Known Member
    Midwest
    4X4 SR5 DC OR Package
    16X8 Raceline Renegade 6's, 265/75R16 Revo 2's, Jason Tonneau, De-Badged, De-Chromed, Wet Okole's, 5100's & Rear TSB, Window's Tinted
    I'm guessing that your tires are rubbing, I get the exact same sound when slowly backing out and turning. It's my tires rubbing on something, even though I trimmed the piss out of my front mud flaps. I should probably just remove them.
  4. Oct 17, 2010 at 5:57 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Might be your lsd in the rear if you have it.If so,you probably just need to add some friction modifier.
  5. Oct 28, 2010 at 5:36 PM
    malander
    max
    01 limited trd 4x4
    hmmm ima thread jack here and say that im lifted and still have stock tires and an e locker in the rear
  6. Jan 13, 2011 at 10:56 AM
    visiontacoma
    visiontacoma Well-Known Member
    San Bernardino, CA
    07 Toyota Tacoma Prerunner TRD Sport
    URD TCAI, URD Maf Cal, NST Crankshaft Pulley, Magnaflow Muffler, 5100s w/ TSB leafs, BHLM, Anytime Foglights, Smoked Tail lights, Grillcraft, WeatherTech Floormats, Scangauge II, Custom TRD Sport Stickers, Debaged w/TRD emblem, Goodyear Wrangler Silent Armors
    Im having this same issue where when i turn from a stop i feel a vibration coming from the front wheels. Started at 30,000 miles and is progressively getting worse. It seems to really vibrate after a long drive when turning in a parking lot going slow.
    My set up is a 2007 prerunner TRD sport w/ 5100's set at .85 and TSB leafs in the rear. Also running 265/70/17 wrangler silent armors.
    First i thought it was my passenger wheel bearing so i replaced it... 300 bucks later n still had the vibs =( I've replaced the brakes pads thinking that might be it n still have the vibs. Highly think its my rotors cuz i would step on the brake and have no vibs at the steering wheel. Plus going strait from a stop there is no issue of any vibration. Only think i can think of is if its my rear LSD. I replaced the fluid at 30k with Lucas diff fluid and a tube of LSD additive. Reason why I suspect its the rear diff is because the vibrations get alot worse the more the truck is warmed up.
    Anyone else have this similar issue??
  7. Jan 13, 2011 at 3:08 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    You guys have lifts? Check the back of your lower control arms...tires are probably rubbing on them. I had the same thing at first becsuse the camber was in "spec" but far from perfect. I bitched to the dealer and they did a better job on the alignment. No more rubbing, and less vibes.
