Has anybody successfully remedied their clutch shudder?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew61987, Mar 1, 2017.
  1. Mar 1, 2017 at 5:50 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Mmmmm Slash X!
  2. Mar 1, 2017 at 6:07 PM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    Glad I found this thread. My 12 does this, I'm at 93k miles. Only when cold and at the same damn stop sign on my way to work in the morning. The clutch feels fine all day after it is warmed up. So weird.
  3. Mar 7, 2017 at 3:58 PM
    SandinmyTaco
    SandinmyTaco Gonna Catch'em All
    Fort Benning, GA
    2015 SR5 4x4 6 Speed SSM DCSB
    Prerunner to 4x4 Mod Wet okole seat covers Weathertech digital floorliners Yellow wire mod SCS F5s gunmetal 16" 4.5bs 265/75/16 Cooper ST Maxx ARE CX Camper Shell
    my 15 does this since about 10k miles i now have 20k on it. it usually happens to me when it gets in to the low 40's over night. i did change out my trans fluid recently but it has had no effect on it. this is my first manual trans that i have driven full time i thought it was me, i have since tried to adjust for it, but to no avail. it does go away after about 2 miles or so.
  4. Mar 16, 2017 at 12:45 PM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Update:
    The weather has warmed ever so slightly, maybe ~45-50 degree mornings instead of 30s, and this has been enough to essentially erase my morning clutch shudder problems.
    This has me thinking. When the shudder does happen, it happens for several starts. Plenty enough to warm it up by 10 degrees. So why does such a mild increase in morning temp mostly eliminate it?
    Only thing I can think of is it has less to do with temp and more to do with water/condensation.
  5. Mar 16, 2017 at 1:12 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    A clutch chattering when cold is normal for any manual transmission vehicle, but it should go away after a few engagements once the clutch warms up. In addition, clutch/brake fluid is more viscous when cold, especially below freezing, which is why your brake and clutch pedals take more effort to press when it's cold outside. The fluid becomes even more viscous over time because it's hygroscopic which means that the older it is, the more water it has absorbed. If the clutch fluid is too viscous, the clutch may not respond directly to your pedal input and it may effect clutch engagement/disengagement.
    If your clutch chatters more than it should, it usually means that the clutch friction surface or flywheel surface is unevenly worn or damaged. Also it's a good idea to flush your clutch fluid and brake fluid after a few years to get the water out of it.
  6. Mar 16, 2017 at 1:14 PM
    nh_yota
    Jeff
    Portsmouth, NH
    It's a combination of both.
  7. Mar 16, 2017 at 1:30 PM
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    Owned my '05 since new and it was doing this back then, almost from day 1. Mostly when cold on first start of the day but also when it's raining. Goes away once warmed up. Clutch squeak fixed and in fact entire tranny replaced under warranty (popped out of 4th gear under load). Annoying but no other issues that I've looked into are wrong with it (motor mounts, oil leak, etc.). Been driving manual trannies since I was a kid 40+ years ago, and currently own other manual vehicles.
    Odd thing is, it is not a true slipping clutch. By that I mean when towing 5000+ lbs it goes away fast even when cold and no further issues. So it must be something like the material on the clutch absorbs moisture, and a thin layer at that, which goes away quickly once a little bit of friction heat is applied. If it were oil it would not go away that fast. I have another vehicle with a true (but tiny) rear main seal leak I have not gotten around to fixing and it definitely can slip. Tacoma is nowhere near that.
