Has anybody welded their Caster Alignment Cam tabs??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDSPORTtaco, Oct 12, 2011.
  1. Oct 12, 2011 at 3:34 PM
    TRDSPORTtaco
    TRDSPORTtaco [OP] Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    I had my alignment done today to fix my caster and the tech told me after he finished that the tabs kept bending and they should be reinforced with a spot weld. Has anybody done this? Or know where exactly the spot welds should be? I'm guessing right behind the tab so it cant bend backwards and go flat, but wanted a second opinion.
    Anybody?
  2. Oct 12, 2011 at 5:20 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    yes you want to weld the outside of the tab that keeps the eccentric bolt in place, so it dosent fold out. with stock arms if your careful you can weld them up without taking the arm out . but if you have aftermarket arms or longtravel you need to take the arms out so you dont damage the polyurethane bushings. you just have to make sure the weld fillet is wider than normal.
  3. Oct 13, 2011 at 12:43 PM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Ok Thanks!
  4. Oct 13, 2011 at 12:46 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yep. If you browse thru my gallery you'll find pix.
  5. Oct 13, 2011 at 12:54 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Check out PSU taco85's build , he got some gussets for his
