Has anyone added cruise control to a (13 base) manual
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Noercarr, Jun 23, 2023.
  1. Jun 23, 2023 at 8:02 PM
    Noercarr
    Noercarr [OP] Active Member
    PNW
    13 Access 2.7 5MT
    I've ordered the stalk, wire and clutch pedal switch. Watched a video and it looks pretty straight forward, except it was done on an automatic and I've still gotta figure out the clutch switch install.
    HtxTaquito likes this.
  2. Jun 23, 2023 at 8:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Depends if your truck is pre-wired, do you have the 2.7L or 4.0L engine?
  3. Jun 23, 2023 at 8:09 PM
    Noercarr
    PNW
    13 Access 2.7 5MT
    2.7. I've been reading a lot of accounts where they're almost always prewired. I'm prewired for a backup camera for sure
    Dm93[QUOTED] likes this.
  4. Jun 23, 2023 at 8:11 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Well here's the wiring diagram if you need it.
    Daigle6 and Noercarr[QUOTED][OP] like this.
  5. Jun 23, 2023 at 8:12 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I did my ‘05. It’s not hard. Post up if you get confused. Switch and stalk and de-pin the horn and you’re good to go.
    Dm93 and Noercarr[OP] like this.
  6. Jun 23, 2023 at 8:15 PM
    Noercarr
    PNW
    13 Access 2.7 5MT
    Incredibly helpful, thanks man
  7. Jun 23, 2023 at 8:16 PM
    Noercarr
    PNW
    13 Access 2.7 5MT
    That's what I like to hear
    daveeasa[QUOTED] likes this.
  8. Jun 23, 2023 at 8:21 PM
    daveeasa
    David
    PNW
    It’s quite a satisfying mod. I’m still working through clutch start cancel. Those and fog on the stalk are the trifecta of 2nd Gen base SR MT mods.
    Noercarr[OP] likes this.
  9. Jun 23, 2023 at 8:23 PM
    daveeasa
    David
    PNW
    Did the cruise a day or two before a 1000 mile move, decided to pre stage the 2nd Gen. Worked perfectly. Of course the 2.7 has no balls so don’t expect it to hold in 5th up steeper passes but that’s not Cruz’s fault :)
  10. Jun 23, 2023 at 9:35 PM
    Noercarr
    PNW
    13 Access 2.7 5MT
    I've got a 2000+ mile round trip in a month, just need to get it in by then! Please update here if you get it installed, I'll do the same.
  11. Jun 24, 2023 at 6:04 AM
    daveeasa
    David
    PNW
    My cruise went in last summer. I have clutch start cancel planned out, is that what you’re asking about? Fogs on the stalk will be later on.
  12. Jun 24, 2023 at 6:40 AM
    Noercarr
    PNW
    13 Access 2.7 5MT
    Yeah, the clutch disengagement switch
  13. Jun 24, 2023 at 6:45 AM
    daveeasa
    David
    PNW
    Noercarr[QUOTED][OP] likes this.
  14. Jun 24, 2023 at 7:44 AM
    Noercarr
    PNW
    13 Access 2.7 5MT
  15. Jun 26, 2024 at 4:15 AM
    HtxTaquito
    HtxTaquito Member
    2013 Single Cab Tacoma 4x4
    Can you post a link of what setup you ordered, and have you gone through with this install? I have a 2013 single cab 2.7 4x4 that I’m looking to add cruise control by next weekend and everything I’ve found has been very detailed but for AUTO, Mines manual and this seems a bit more work
  16. Jun 26, 2024 at 2:21 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    The ECM is programmed to accept the CC stalk and wiring. The't only potential issues are that I have read some units have the wiring between the column and ECM, and some don't.
    I have also heard of some having a clock spring that didn't connect between the st8eering pad and the S8 connector at the bottom of the column. My 2013 base/auto HAD it, but the trace was worn through so I had to get another one. You can easily check by checking for continuity between the pins in the steering pad behind the steering wheel and the correct pin in S8. I also had to run the wire from S8 to ECM as it wasn't prewired. It is pretty straightforward.
    deanosaurus likes this.
