Has anyone been able to tame the leak?
Discussion in 'Tonneau Covers, Caps and Shells' started by tacoman00, Nov 12, 2021.
  1. Nov 12, 2021 at 6:54 PM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Hampton Roads, VA
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    Recently bought a Leer 100XQ. I know after reading that making these things water tight can be a tall task. I went around the rails with a tube of Flexlock and it solved most of the leakage. The only spot I'm still getting decent leakage is in the front corners of the bed. I've read there's some pretty massive holes where the cap meets the bed there. Anyone have any solutions to stop the leaks in that area?
  2. Nov 12, 2021 at 7:42 PM
    HeyItsBen
    HeyItsBen Well-Known Member
    Ben
    Sigh...been going through this for a month now with a new Leer topper. I'm just seeing the sides leak for the first time, not sure how with the topper reaching below the rails and the truck sitting.
    I have had some success with the front corners which is where it was leaking the most. Water would pool on the front rail and seep in so I added this:
    https://www.amazon.com/gp/product/B083RBM73N?ie=UTF8&th=1
    I just stuck it on like a flap that covers the front rail the entire width of the truck. I had some help from my girlfriend who stayed outside the truck and got the corners in place, I was able to pull the adhesive backing and press it on from inside the shell. There are two gaps, one where the shell sits on the rail,and one where the rail is bolted to the truck, so we applied two layers.
    So far it's been dry in heavy rain and may have actually fixed it, but it's only been a few days. Not sure if it will even stay on or not.
    How/where did you apply the flexlock?
  3. Nov 12, 2021 at 8:18 PM
    tacoman00
    Hampton Roads, VA
    So the stuff I used is called Dynaflex by DAP. I can take pictures when I get home from work in the morning but basically I got a caulking gun and just ran a bead under the lip of the shell edge from inside the bed. I went around all 3 sides and it fixed the leaks I was having on the sides towards the back of the bed near the tailgate. It also decreased the leak at the front, but looking for a solid solution.
    HeyItsBen likes this.
  4. Nov 12, 2021 at 8:21 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 4x4 V6
    1 fully operational Death Star
  5. Nov 12, 2021 at 8:22 PM
    tacoman00
    Hampton Roads, VA
    What's you guys' opinion on some of that expanding foam in a can and just going to town in the front corners from the inside? My biggest concern is it seeping out and ruining the paint on the outside of the truck.
  6. Nov 12, 2021 at 8:44 PM
    WhiskeyHole
    WhiskeyHole Well-Known Member
    Columbus, Oh
    2013 PyriteMica
    Mostly stock
    Disaster in a can. Please don't do that. Just keep at it with silicone and try to make your seal on the outside as much as you can.
  7. Nov 12, 2021 at 8:52 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    Would flex seal spray work?
  8. Nov 12, 2021 at 9:14 PM
    tacoman00
    Hampton Roads, VA
    I did also consider the ole' flex seal. I'm just hesitant in general about "As seen on TV" products.
  9. Nov 13, 2021 at 7:05 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    So the front is .5" higher than the sides. Has anyone ever checked to see if ARE/Leer build these with the step down to the sides, or is it flat and they just throw it on there? Asking for thousands of others. LOL
    Zim
  10. Nov 22, 2021 at 7:07 PM
    Roadhouse
    Roadhouse Member
    2022 TRD Offroad V6 Manual Transmission
    Flex Seal is legit. Can't speak to how it would work for your situation, but the product itself is really good despite being "As Seen on TV".
  11. Nov 25, 2021 at 2:59 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Here's what you need:
    Toyota part nos. 6254104010 & 6254204010.
