Has anyone been successful with led blinker swap?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toojayz, Aug 3, 2011.
  1. Aug 3, 2011 at 1:55 PM
    toojayz
    toojayz [OP] Well-Known Member
    Jim
    Northern NJ
    2011 TRD Sport 4x4 DC MGM SB
    Like the thread says, before I spend money has anyone done the swap for our front blinkers? I've done the parking light mod where the third filament is on with the parking lights (the low beam if the blinker) and I think the final result would look really good with led's. I've read a lot about load resistors and just trying to get a feel if it's worth it.
  2. Aug 3, 2011 at 5:13 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    There are flashers designed just for LED's don't fool with resistors.
  3. Aug 4, 2011 at 5:22 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Any suggestions about which flasher relays work and where to get them?
  4. Aug 4, 2011 at 11:25 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    The flasher relay in a Tacoma isn't like the old-school plug in job. I doubt you'll get one designed for the purpose.
    Another problem is if you are just using LED replacement "bulbs" (not an actual LED retrofit), it won't work as well as the filament bulb. Others won't be able to see the lights as well, just because the housing isn't designed for it. LED's have a much different output pattern (more directional).
  5. Aug 4, 2011 at 12:28 PM
    JKD
    JKD Well-Known Member
    That is why replacement bulbs, when properly designed, include multiple LEDs oriented to mimic the light distribution of incandescent bulbs.
  6. Aug 4, 2011 at 12:54 PM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    yes, the older 3mm and 5mm LED's are very directional....but the SMT towers are 360 which fill out the housing area very well.
  7. Aug 4, 2011 at 1:44 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I tried a few different styles of LED but none were bright including one with the diodes all over it.
    Some just wouldn't work in the socket. I wasted some money buying and then returning them all.
    I tried this because I have DRL and wanted to prevent any melting or scorching of the lens.
    I stuck with regular bulbs eventually and don't have any lens melting problems anyway.
    I did use a type "5702KA" bulb which has a slightly cooler running temp than the factory bulbs.
  8. Aug 6, 2011 at 7:32 PM
    Eltacos
    Eltacos Well-Known Member
    BFE CA
    TRD Off Road
    LED conversion on every accessible bulb, TRD exhaust (dealership threw in for free along with the Blu-Logic).
    On a side note, I installed 3ohm load resistors on the rear turns only. I mounted them on a bracket for heat isolation and used the high quality heat sink type of resistors, not the cheap eBay ones. I like this setup because I didn't need a separate pair of resistors for the front after I disabled my DRLs and wired to use Switchback LEDs on the front. Now I am looking at the Red / White style Switchback LEDs to modify my rear turn signals to act as reverse supplement lighting (just for the heck of it).
  9. Aug 6, 2011 at 8:11 PM
    krap22
    krap22 Well-Known Member
  10. Aug 7, 2011 at 9:58 AM
    krap22
    do you like them better than the stockers? Are they significantly brighter?
  11. Aug 7, 2011 at 1:16 PM
    toojayz
    Jim
    Northern NJ
    ^This, how do you like them?
