Has anyone bolted on a TRD Supercharger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mandude2007, May 10, 2014.
  1. May 10, 2014 at 8:39 AM
    Mandude2007
    Mandude2007 [OP] New Member
    East Tn
    07 Tacoma SR5 OffRoad
    None yet
    I have a 2007 SR5 Offroad with a 4.0 to 6sp manual.
  2. May 10, 2014 at 10:02 AM
    gearcruncher
    Canadain bumper technician
    Try the search button at the top right . I am sure someone on this site has done it:D
  3. May 10, 2014 at 10:06 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Um... Yes I have
    /Thread?
  4. May 10, 2014 at 11:15 AM
    zmw
    zmw Well-Known Member
    SATX
    2014 TXproBAJA
    none
    Yes
  5. May 10, 2014 at 11:19 AM
    memario1214
    Colton
    Missoula, MT
    Okay hones answer. Yes, a decent number of us have actually. It gives a nice boost in power and is really the only standalone performance upgrade that is worth it IMO. Depending on who you talk to you will see the same or lower mpg (mine got lower). It will cost you somewhere in the range of $3800-4300 to buy and another $500-1000 to have it installed if you go that route.
  6. May 10, 2014 at 11:21 AM
    Large
    Large Red
    Mine got substantially lower, and I didn't see any real gains before 3k rpms
  7. May 10, 2014 at 11:23 AM
    memario1214
    Colton
    Missoula, MT
    Actually... This. I have experienced the same result.
  8. May 10, 2014 at 11:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    OP, you should really venture into the "Performance and Tuning" section. :thumbsup:
  9. May 10, 2014 at 3:03 PM
    zmw
    SATX
    2014 TXproBAJA
    none
    What were you expecting? like any forced induction it needs power to make power, the truck isn't making hardly any power below 3000 rpm, if it were a turbo it'd need more exhaust energy to generate boost, because it's a supercharge it needs RPM on the crank, obviously the higher the RPM the higher the boost potential.
    If you want instant throttle response and power the only REAL way to do that is change the mechanical properties of your engine, either increase displacement, increase compression ratio, increase tuning via timing and fuel changes, etc - if you use some type of FI to make up for lack of mechanical power the trade off will always be less power in the low end
  10. May 10, 2014 at 5:41 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Welcome. Who are you? What are your knowledge credentials on the subject?
    You haven't been here long enough to know that Memario already knows and understands that. :thumbsup:
  11. May 11, 2014 at 6:27 AM
    Mandude2007
    East Tn
    None yet
    Yes Im thinkin it wouldnt really be worth the money to do. Hell, its pretty fast now, I love the 6 speed. If i was to invest that much in a motor i would just build a small block chevy. Thanks for everyones input.
