Has anyone bought a “Preece Precision LLC” Co2 tank?
Discussion in 'Product Reviews' started by DustyTaco31, Mar 15, 2021.
  1. Mar 15, 2021 at 5:48 PM
    DustyTaco31
    DustyTaco31 [OP] Well-Known Member
    2018 Quicksand Taco TRD Sport
    Am curious if these are any good, the price seems good.
  2. Mar 15, 2021 at 5:50 PM
    DustyTaco31
  3. Sep 7, 2023 at 2:58 PM
    Ace83
    Ace83 Well-Known Member
    TX
    SR5
    Bilstein Front shocks, Rough Country 3" lift kit, 5" black railway running boards
    These seems better than the premium onboard air systems, comparable in price
  4. Dec 3, 2023 at 8:23 AM
    OGTodd
    OGTodd Member
    Lewis
    84,88,90 SR5 23 TRD DCSB
    84 dual case,5.29’s 37x14.50 Iroks
    I purchased my tank and regulator from a welding supplier. I used a fire extinguisher bracket. The other trick is getting it filled at a fire extinguisher shop. Cheaper fills, your nice bottle doesn’t get beat up. I usually got a year on a fill airing up 37x14.5 Iroks from 5-45 psi
  5. Dec 3, 2023 at 8:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    we use Preece Precision fittings all the time, with good results. They are great quality. That said, Co2 Tanks are better purchased at a Welding store, or Gas Supplier, as they tend to be less expensive at those locations.
  6. Dec 3, 2023 at 8:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I should point out that we mostly use their Fixed pressure regulators. The Dual Gauge regulators are kinda useless for us, as the Tank PSI will always be the same up until there is no Co2 left, and the 150 psi is what we most commonly use, so no need for a gauge. Any time inflator uses we use calibrated gauges for.
