Has anyone combined a long travel setup with a 6" lift ?kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Btnewman, Dec 18, 2011.
  1. Dec 18, 2011 at 9:16 AM
    Btnewman
    Btnewman [OP] Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    I am kind of directing my truck to be a "one truck fits all" setup. I live close to moab ut, and I also like to haul nuggets in the desert, I know going this route my truck wont be amazing in rocks or the best in desert.
    I am thinking about combining a pro comp 6" kit with a Long travel kit, not sure which one to go with for this. I am not really interested in a solid axle setup and I want the longer travel but also want the extra clearance of a lift kit.
    Has anyone done this or is it just a no good very bad awful idea?
  2. Dec 18, 2011 at 9:20 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    No good, very awful idea...
    Long travel can give you clearance and high speed performance. If you ick your spring rates properly, you can get a compromise of speed and crawling performance.
  3. Dec 18, 2011 at 9:32 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
  4. Dec 18, 2011 at 10:02 AM
    Btnewman
    Benjamin
    Grand Junction co
    welp, scratch that idea...
  5. Dec 18, 2011 at 10:17 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    It is possible... Well almost anything is possible... But it would be a waste of money and more than likely dangerous for anything other than mall crawling. Using LT for what it's meant for puts a lot of stress on the suspension and truck that more than like a drop bracket lift couldn't handle. But hey... It's your truck go for it
  6. Dec 18, 2011 at 10:42 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I think the rear driveline will limit you, as the U-joints then have to accommodate both a 6" lift and long travel.
    6" lift isn't good for crawling. You get better clearance, but the center of gravity is much higher, so you are more likely to tip over. An LT kit that gives ~3" of lift will crawl very well.
