Has anyone come up with a mess-less filter removal idea?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whttaco2whl, Feb 6, 2016.
  1. Feb 6, 2016 at 9:22 AM
    whttaco2whl
    whttaco2whl [OP] Well-Known Member
    KC
    North of LA
    2009 Tacoma base model, 2Whl 5Lug
    None
    This 4cyl motor is a good motor, and I have been surprised at how I have NOT been aware of power loss. That said, the oil filter on the RH side of the engine block is sure a messy design. There seems to be no way to a avoid oil running down the block, and following the trans cooler lines to the rear. This seems to be a normal thing with the Toyota engineers, as our Highlander V-6 filter is mounted at an angle, oil side down, on the front of the engine! At least it does have a small catch basin that collects the oil and directs it into one stream to allow a pan to catch it. (If you are careful and do the job slowly) This Tacoma makes no attempt at all to recognize the issue. SO>.......... Has anyone come up with something that works? (Besides Jiffy ruin???)
  2. Feb 6, 2016 at 12:13 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
  3. Feb 6, 2016 at 2:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I just use a gallon zip lock bag and work real slow giving it time to drain.
  4. Feb 9, 2016 at 7:40 AM
    whttaco2whl
    KC
    North of LA
    None
    Thanks, that Form a Funnel may work well! Had not seen that yet.
  5. Feb 9, 2016 at 11:11 AM
    DRP6833
    DRP6833 Well-Known Member
    Dave
    Frederick, CO
    2014 Tacoma I4 4WD
    I installed a remote oil filter on my '95. An adapter replaced the filter, two hoses ran to the bracket that held the filter. I mounted that on the wheel well inside the engine compartment where it was accessible. Sorry but I don't have any pictures of that set-up and the truck was sold a couple years ago.
  6. Feb 9, 2016 at 1:20 PM
    george3
    New Jersey
    It worked for me. Just stick it up between the motor and the filter and bend it so it stays in place and drips into your pan. Enjoy.
  7. Feb 13, 2016 at 8:01 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I use plastic grocery bags. Double them up because they tear. First, for a remote filter, pull off the drain cap on the bottom, and break the filter loose. Put your hand up inside the bags and grab the filter. Pull the bag up around the filter as far as it will go and hold it there with your other hand. Unscrew the filter. The bags will catch the filter and all the oil. Clean everything up, replace the drain cap and filter.
  8. Feb 13, 2016 at 1:05 PM
    george3
    New Jersey
    I put my hand in the bag and pull the bag up my arm as far as it will go and I use the form a funnel - loosen the filter - the oil runs down the the bag instead of my arm and down the form a funnel instead of the motor.
  9. Feb 14, 2016 at 6:40 PM
    Eselhengst
    Eselhengst Well-Known Member
    South of Abbotsford
    2011 Access cab TRD Offroad
    Sway-A-Way 2.0 coilovers and rear shocks Wheelers 8 leaf springs and superbumps ARB front bumper Trail Gear sliders RCI aluminum skids URD Spec-U exhaust etc.
    Not sure how much the 2.7 has changed, but on my 2000, I would cut the top off a quart gatorade bottle, loosen the filter, then slip the cut bottle up over it and spin it off. That would catch all the oil and was the perfect size for the filter.
