Has anyone deleted their cat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Jul 16, 2015.
  1. Dec 13, 2015 at 4:13 AM
    #61
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
  2. Dec 13, 2015 at 10:30 AM
    #62
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    Im not sure this is correct but I've read on here saying that the front o2 will use the rear o2 to reset itself. And thats why you may get poor mpg, you can also get poor mpg from a cat thats falling apart, and that will throw the code.
    You also said the ecu with switch from lean to rich for the emissions system to work, but it switches because its constantly trying to adjust the a/f based on conditions to reach stiochemtry conditions of 14.7:1 ratio. It doesn't just switch from Rich to lean on purpose, its just adjusting to get to 14.7:1. Your short term and long term fuel trims are measuring the amount of this adjustment.
  3. Dec 13, 2015 at 7:04 PM
    #63
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    When my cat came apart the only time it negatively affected anything was when chunks tried to go down the exhaust and plugged it up. This caused a noticeable power loss but other than that I dont remember any other issues. Even the light only came on once or twice by that point and by then there was pretty much nothing left of the cat other than the chunk blocking the exhaust.
  4. Nov 1, 2019 at 5:43 PM
    #64
    RianH15
    RianH15 Active Member
    Rian
    99 Tacoma 4X4
    Back pressure is NEVER good for an exhaust system. The faster the gasses get out the faster air can get in through the intake and into the engine to complete the next cycle. If you restrict the exhaust it only reduces the efficiency of the engine. The common mistake is between back pressure and scavenging. Scavenging is basically the effect of the high velocity gases in the exhaust actually sucking other gases out behind them. This is why headers have to be at specific angles and diameters, so that the velocity leaving the engine will allow for scavenging which again increases efficiency. No where in an exhaust system do you want any unnecessary restrictions. If you want better performance and efficiency you would want no restriction. On the other side of the coin if you make your exhaust too wide then, according to Bernoulli‘s principle you decrease velocity and increase pressure which is not good. There’s a sweet spot for it and that’s why it takes engineering to design an exhaust system.
    Thatbassguy likes this.
  5. Nov 1, 2019 at 6:01 PM
    #65
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Thank God some people here actually understand exhaust!
    I always laugh when people say that stuff. It's funny how many people just go on believing the old school misconceptions without bothering to actually read about it.
    RianH15[QUOTED] likes this.
  6. Nov 1, 2019 at 6:58 PM
    #66
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    Thank you for setting the record straight 3 years and 11 months later...
    RianH15[QUOTED] and Brake Weight like this.
  7. Nov 2, 2019 at 4:47 AM
    #67
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    and theres the "youl burn your exhaust valves up guys"
  8. Nov 2, 2019 at 8:10 AM
    #68
    bodhi armor
    bodhi armor 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    I’m seriously considering deleting my cat..
    That is to say that if my fiancé’s cat pisses in my house one more time I’m going to delete the shit out of him!! Likely with my 300 win ultra mag
    Luv my yota, RianH15 and Holy schmidt like this.
  9. Nov 2, 2019 at 5:27 PM
    #69
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    While I agree with your end result here, I think that 300 Win Mag might wreck the upholstery if you do it inside. Better stick with something cleaner and quieter, like "taking them to the beach" (crate and a water trough), or a simple 9mm hollow point.
    But if they're an outdoor cat as well, then blast away with the Win Mag and see if anything is left...
    Was my hatred for cats too graphic? Sorry.
    RianH15 likes this.
  10. Nov 4, 2019 at 4:24 PM
    #70
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I’m catless and it’s noticeably louder. The CEL will come on if it idles too long. If you stay moving it stays off. But seems to get a mile or two better per gallon when the CEL is on and it’s open loop.
    RianH15 likes this.
