Has anyone disassembled the Climate Control panel in a 3rd Gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cmillz421, May 27, 2020.
  1. May 27, 2020 at 8:18 PM
    cmillz421
    cmillz421 [OP] Member
    Colin
    2017 Inferno Tacoma SR5 V6 4x4 DCSBAT
    3" Rough Country Suspension Lift/Struts, Pro Comp UCA, 33" Nitto Ridge Grappler G2's on 17x9 -12 XD Holeshot Wheels
    What up guys, I recently popped all the gray trim off of the interior in order to paint it/color match it. Ended up disassembling the climate control panel and I think I messed up with aligning the little white "gear" dials that go behind the control knobs. My mode selector doesn't change to any other setting when turned, it just seems to blow air from the dash defroster vents and the floor vents. Does anyone have experience with this? I've torn the dash apart multiple times and I'm at my wits end with this thing! Please any help would be a blessing at this point!
  2. May 27, 2020 at 8:19 PM
    mullett757
    mullett757 Well-Known Member
    Joe
    Virginia Beach
    2020 White TRD Sport DCLB
    I did the same thing and made a thread that has the solution, looking for it now to send the link
  3. May 27, 2020 at 8:20 PM
    mullett757
    Joe
    Virginia Beach
  4. May 27, 2020 at 8:26 PM
    cmillz421
    Colin
    Thanks bro, much appreciated!!!
  5. May 27, 2020 at 8:43 PM
    mullett757
    Joe
    Virginia Beach
    No prob! Sorry there’s no pictures. Was too excited to remember to Take them when I figured it out lol thought I was screwed
  6. May 27, 2020 at 9:03 PM
    cmillz421
    Colin
    dude, Im pretty sure I aligned all the arrows that last time I re assembled it, however, I cleaned all that white goop off like a dumbass. Do you think that might be messing with the connection to the tiny circuits on the board? Cuz right now, my mode selector only changes to defrost. When I rotate it towards face vents position it just goes to floor-defrost setting... Super annoying
  7. May 27, 2020 at 9:03 PM
    cmillz421
    Colin
    Should I buy and re-apply more of that white goop?
  8. May 27, 2020 at 11:52 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Not had mine apart but I’d guess that the white goop is lithium grease. Someone smarter should chime in sooner or later with a answer.
  9. May 28, 2020 at 4:45 AM
    mullett757
    Joe
    Virginia Beach
    So I found that I had to set the mode on the third setting which is the middle one (should have two on either side of it and then line the arrows up for it to work. The grease should just be grease but if it changes that means your board is still good.
  10. May 28, 2020 at 5:14 PM
    cmillz421
    Colin
    Sweet deal man, Ill give it a go and see what happens. Thanks so much man
    mullett757 likes this.
