Has anyone done the Bilstein 6112/5160 lift with 285/70R/17 tires?
Discussion in 'Suspension' started by aydarius, Sep 4, 2021.
  1. Sep 4, 2021 at 12:05 PM
    aydarius
    aydarius [OP] Member
    Hello, I'm new to this group.
    I have a 2019 Tacoma OR 5ft bed and I plan on lifting my truck and getting a bigger tires/wheels. I want to do more serious off-roading, but nothing super crazy. So after the long research I decided to go with this stuff:
    - Bilstein 6112/5160 lift
    - SPC upper control arms
    - Icon 1.5 add a leaf
    - Method wheels 703 (bead grip) 17x8.5 +00 offset
    - BFG KO2 A/T 285/70r/17
    If anyone has done something similar, please share your experience with me. I just wonder if 33" tires will fit with 6112's without rubbing. Also, what is your overall lift height increase?
    My local shops are out of Bilstein and only have Rough Country 3" strut lift, which I don't want to do lol.
  2. Sep 4, 2021 at 12:53 PM
    helium89
    helium89 Member
    2021 TRD OR
    If you’re actually fully articulating the suspension, a lift isn’t going to do anything to reduce rubbing. If the suspension doesn’t see full compression, the lift will help. Generally, the wider the tire, the more likely you are to rub. Running wheels with less backspacing will help clear the UCAs, but they will increase the chance of rubbing on the fender, cab mount, and pinch weld.
    If you don’t want to cut anything, your best bet for a 33 inch tire is going to be a 255/80r17 on wheels with the largest backspacing that will still clear the UCAs. Then, you’ll want to max out your caster at the LCAs, put the ball joints on the SPCs in the most forward position you can while still getting the caster you want, and be prepared to use a heat gun on the fender liner.
  3. Sep 4, 2021 at 3:46 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Lots of people. But be prepared to cut and trim
    71tattooguy and aydarius[OP] like this.
  4. Sep 4, 2021 at 4:10 PM
    aydarius
    Hmmm... I've just watched a couple youtube videos and people didn't cut or trim anything. https://www.youtube.com/watch?v=YX4hIOjxM-Q&list=LL&index=1
    Do you have any other alternative lift options? I couldn't find any other 3-inch suspension lift kit for the buck, besides Rough Country that comes with 3-inch lifted N3 struts and V2 rear shocks. What about the Bilstein 5100's setup?
  5. Sep 4, 2021 at 4:15 PM
    Dalegribble02
    If you just mall crawl you will be ok. But if you offroad and use the suspension it'll will rub guaranteed
  6. Sep 4, 2021 at 4:17 PM
    Dalegribble02
  7. Sep 4, 2021 at 6:09 PM
    aydarius
  8. Sep 8, 2021 at 8:17 AM
    Bedawson
    Bedawson Well-Known Member
    Central Oregon
    2020 DCSB off road - Sold
    | Fox 2.0 | Icon AAL | RRW-7 -12 offset | 285/70/17 |
  9. Sep 8, 2021 at 8:48 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
  10. Sep 8, 2021 at 8:51 AM
    gman2431
    gman2431 Well-Known Member
    I have 6112/5160 but with -12 offset rims. My rubbing is very minimal and I probably drive off road more than most on here.
    aydarius[OP] and Fedup13 like this.
  11. Sep 8, 2021 at 7:26 PM
    aydarius
    What is your 6112 pre load, 6/5 or 5/4?
  12. Sep 9, 2021 at 12:54 PM
    gman2431
    All the way up 6/5
  13. Sep 9, 2022 at 8:36 PM
    Landycruiser
    Landycruiser Member
    2021 SR v6 4x4 Double cab
    Bilstein 6112/5160, full CBI skids, soft topper
    How’s the ride at 6/5? I’m at 5/4 but could use a boost.
  14. Sep 10, 2022 at 6:00 PM
    AA-Ron76
    AA-Ron76 Well-Known Member
    Aaron
    2022 Army Green Tacoma TRD Off-Road
    Mine are at 6/5, after the 6112's with Freedom Off-Road UCA', 5160's in the rear. I have about 2.75" of lift up front and the rear is close to level with the front after installing the Icon 1.5" add a leaf.
    I had to remove the mud flaps up front in order to avoid rubbing the 285/70/17'. I had minor rub on the plastic at full turn on the drivers side. I had the caster pushed out from 2.2 and 2.3 to 3.0 on both sides and the rub is now gone. I am going to do a CMC next week in order to avoid any rub off road.
    Landycruiser likes this.
  15. Sep 12, 2022 at 5:54 AM
    gman2431
    Not bad, I am about dead level with the rear so when I park on any small incline it looks like I am squatting... I might drop one lower to where you are at
  16. Sep 12, 2022 at 8:02 AM
    Landycruiser
    Landycruiser Member
    I’m running OME Dakar medium springsin the rear, so I have a pretty decent rake.
    gman2431[QUOTED] likes this.
  17. Sep 17, 2022 at 10:04 PM
    HafaTacomaDoot
    HafaTacomaDoot New Member
    22 Tacoma V6
    I was wondering if these 6112/5160 struts would be compatible with Pro Comps 6inch setup?
