Has anyone ever attempted to replace the Access Cab's Door Panels in a Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ChaseUA, May 30, 2010.
  1. May 30, 2010 at 8:44 PM
    ChaseUA
    ChaseUA [OP] Well-Known Member
    Chase
    Bama
    Present: 2016 White TRD Sport DC Past: 2010 MGM TRD Sport AC 4x4
    I am aware that the 2009 & 2010 Access Cabs do not have speakers installed in them, but it appears the "insides" of the door are the same as prior models, however the Panels are different since no speakers are installed.
    Would it be possible to replace the entire door panel with those from a 2005-2008 door? If so, does anyone know the part #'s needed?
  2. May 30, 2010 at 8:46 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ...i think mine has speakers...it looks like they do because of the honeycomb looking thingy mobobber on it right above the pocket in the bottom of the door
  3. May 30, 2010 at 8:47 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Yes, you can swap them over.
  4. May 30, 2010 at 8:59 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    You mean a 2005 - 2008 door.
  5. May 30, 2010 at 9:01 PM
    ChaseUA
    Chase
    Bama
    Sorry I'll edit the original post, I was thinking they just began the idiotic idea of foregoing the rear speakers for some crappy panel deals in the headliner...
  6. May 30, 2010 at 9:07 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I wish...i got stuck with them also.
    But yea its possible. Also Exteme Kreations makes the fiberglass panels for them that hold a speaker and sub.
  7. May 30, 2010 at 11:59 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    in order for them to fit tho..you have to cut the original door panel up where the fiberglass panel goes over it. But i digress.. You can from what ive seen just swap the panels out.
  8. Aug 2, 2010 at 12:07 AM
    conradicals747
    conradicals747 New Member
    Adam
    MD
    10 Prerunner
    Extang Tonneaa cover
    What is this Extreme Kreations you speak of, and yes I am a Newbie
  9. Aug 2, 2010 at 3:11 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
  10. Aug 3, 2010 at 8:18 PM
    ChaseUA
    Chase
    Bama
    Thanks for the link jpmorris, I had never "drilled down" deep enough on that site to find what I was looking for.
    They basically come out to $230 each (for each side) - not sure if $460 is worth being able to add rear speakers without cutting etc...
    Thoughts?
