Has anyone ever had a MAF damaged by oiled filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by carmellocafe, May 25, 2009.
  1. May 26, 2009 at 9:35 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I had bad experiences using K&N filters on my taco. I used one for 6 months. In that time period, I had to clean the throttle body 3 times. The filter lets in more dirt, which was clogging my throttle body. The truck would actually get to the point where it would almost stall at idle. I quit using it, went back to a regular paper filter and been fine ever since.
  2. May 26, 2009 at 11:20 AM
    Bre2tSco2t
    Bre2tSco2t Well-Known Member
    Alabama
    Bedrug, Access Limited Tonneau, Tailgate Clamp, Manual Pop&Lock Keyed and Painted to Match, Westin 3" Nerf Bars, 20" Chrome Wheels.
    I am watching this one like a hawk. Chris, I like your answers because there is prove behind them, not just opinions. I am interested also in the AFE Pro Dry and will wait on your test. :popcorn:
    I don't intend to hijack the thread here, but you have mentioned in several posts about you being out of work. What do you do? Why is work off? PM me if you don't want to answer publically, or don't answer at all if it is none of my business. :D
  3. May 26, 2009 at 11:31 AM
    TacoMOnster07
    TacoMOnster07 Well-Known Member
    Pennsylvania
    07 DC 6speed 4x4 BSP Sr5
    BHLM, Grillcraft, Urd SS, Urd TCAI, Urd MAF Calibrator, AeroTurbine Exhaust, TacoTune Single Din, Two 8" Infinity Subs, 12-13000 HID's, Xtreme Bedrack light bar with two KC 4 by 6 lights.
    Carmello before you start saying people have no brains let me ask you, how long have you had your K&N on for? Have you tried the recharger kit? Have you used the proper amount of oil like the bottles says? I did many times, I'm a f"in mechanic, i do things properly. I have had nothing but problems with my maf getting fouled up. Had to clean it at least once a month. It's so bad that when you accelerate it boggs down horribly. I cleaned the filter many times and recharged it properly many times. Everytime nothing but problems. Switched to urd TCAI and amsoil filter and never had any problems. I will never buy another K&n wet filter again.
    Edit: I was not using the drop in filter, this was the K&N cone filter with there kit.
  4. May 26, 2009 at 11:44 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I've been running K&N filters on my truck for the last 18k miles or so and haven't seen any issues. I've also ran them in my quad for hundreds of hours in sand dunes and dusty trails/roads with an open air box and the cylinder still looked like new when I got the motor built last spring. My truck still runs great(noticeably more top end power with the CAI) and when cleaning the filter(every 5k miles or so) i've checked my intake tube for any residue of oil or dust and have found none. The K&N filters do look questionably thin when held up to a bright light though.
  5. May 26, 2009 at 12:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Just because no dust in found in the intake track, doesnt mean its not getting into the engine. An oil sample will show this. Particles larger than 20 microns can cause engine damage, particles smaller than 10 may not cause damage, but CAN cause accelerated wear. Will it happen in 10,000 miles or 150,000 miles? Dont know. In the end, its the consumer that decides what they run, and why on their engine. All of my tests on filters were in "real world" conditions, and many in extreme dust/dirt conditions. After the testing was finished, I will never use a K&N filter, or any other oiled gauze filter, for anything more than straining paint. :)
  6. May 26, 2009 at 1:06 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Yup!:)
  7. May 26, 2009 at 1:23 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Could I send you some samples of my oil for the AFE? I just put it in with my most recent oil change so would I need the OEM samples to compare?
  8. May 26, 2009 at 1:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would need a "before" and "after" sample from the engine. Im gonna do it, just give me some time.
  9. May 26, 2009 at 1:43 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I work at a Chevy dealer in the parts dept. I have sold at least 20 MAF sensors for Silverados that have failed due to K&N air filters. On the Chevys, the MAF sensor is very close to the airbox and oil contaminates the sensor. In fact, in the GM performance catalog, the perfomance air cleaner they sell is a dry one. What this has to do with Tacomas I don't know, but I thought I would just throw out some personal experience. If I ever put a high flow air filter in my Tacoma, I would use a dry one. Why take a chance?
  10. May 26, 2009 at 1:54 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Ran a K&N on my 79 Toyota for 20 + years, about 200,000 on that 20R and filter
    Figure I got my money out of it :D
    Ordered a K&N for my 92 4 Runner the day I ordered my truck and installed it before pulling out of the dealers lot .
    Ran that for 15 + years and about a 145,000 miles
  11. May 26, 2009 at 2:39 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I had the K&N along with the deckplate mod & manual tranny. It made a noticable difference in throttle response. That was the 3.4L.
    I have the AFE pro-dry in my 4.0L and removed the secondary air filter with an Auto tranny. I haven't noticed much difference. But then again, this is an Auto......I haven't played too much with it in terms of going 'all-out' or shifting it manually. I just like the fact I can clean the filter and was hoping for a little bit of gas savings too.
    In terms of gas mileage....seems the 3.4L tacomas adjusted positively to different modifications to help improve gas mileage. I've already done the same mods on this 4.0L as I've done on the 3.4L and my MPG stayed the same as the day I bought it. They just arent' the same...
  12. May 26, 2009 at 8:48 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Then I got ethanol for brains. :eek:
    The first time I oiled my TRD I used half the bottle in the kit. It dripped (inside and out the filter) for days. I followed the instructions pretty carefully, but they don't give a clue how much to use. The diagram shows oil pouring onto the filter.
  13. May 26, 2009 at 9:03 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    On my '05 Altima, yes, and I never oiled it, only used as is from the factory. On the Tacoma, I'm intelligent enough to have learned my lesson the first time.
  14. May 26, 2009 at 9:07 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    that was what I experienced with the Altima. Blackstone tests before and after showed very high silicates with the K&N as opposed to the AEM Dryflow I used after my MAF died.
  15. May 26, 2009 at 9:20 PM
    #35
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    I clean my air filter every 15k miles (every 3 oil changes). I go home and travel dirt roads. It may be overkill sometimes, but I have a clean filter.
  16. May 26, 2009 at 9:28 PM
    #36
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Many of us have the AFE ProdryS. I haven't done any oil testing with it yet, though.
  17. May 26, 2009 at 9:32 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Go figure. :D
  18. May 26, 2009 at 11:32 PM
    #38
    FL4x4Taco
    FL4x4Taco Well-Known Member
    KN filters won't go near any of my cars. I've had a MAF go out using the FACTORY OILED K&N filter!! So if they can't oil it correctly, we sure can't!!! I've also had upper ends off of many cars running K&N's, trust me... it's not pretty. Cars run better with a Paper filter. Of course K&N is going to try and sway your opinion.... they want to sell you a filter.
  19. May 27, 2009 at 2:56 AM
    #39
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Do you mean the Check Engine light or the Maintenance Required light? If you actually mean the Maintenance light then no the K&N would have nothing to do with it, the maint. light just counts miles since it was last reset to remind you when to change your oil. It blinks at 4500 miles and stays solid at 5000 miles.
    I think you might have read his post wrong...he said Maintenance Required light not Check Engine light.
  20. May 27, 2009 at 2:59 AM
    #40
    FoxySandChick
    Kristin
    Henderson, NV
