Has anyone ever had bad service like this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brian, May 24, 2010.
  1. May 24, 2010 at 8:47 AM
    brian
    brian [OP] Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Had a u-joint replaced the other day. DC taco has two piece driveshaft right? Well, even the 'dumb mechanic' that I obviously am, KNOWS to mark the driveshaft when you pull it apart so everything remains balanced when you reinstall.
    Well they didn't. My zerc fittings used to be all aligned on the same side. My 2 driveshafts have been reinstalled 180 out from each other, causing the annoying vibration hum inside the cab at 60mph, and most recently, a mild driveline shutter at 20mph. The work was CLEARLY done incorrectly.
    Heres my receipt:
    Basically the service manager told me I'm an idiot and to shove it, even when I called out his bad service. He claimed the driveshaft was 'in-phase' and the vibration was the tires. You'd think since I've been driving this truck for the past 70k miles, I'd know what my tires feel like right?
    Does anyone have the service manual portion for replacing a u-joint or driveshaft maintenance at all? I want a copy of it, my factory maintenance manuals don't seem to have much on drivelines. I would greatly appreciate any help I could get on this matter. I want to shove a reference in his face, and possibly down his throat.
  2. May 24, 2010 at 8:56 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Here you go :
  3. May 24, 2010 at 8:59 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Write Toyota and get that service manager fired! I've gotten the service manager at BMW fired for stupid shit like that. Go talk to his boss and make a scene inside the shop, that'll get your problem fixed REAL quick!
  4. May 24, 2010 at 9:01 AM
    brian
    Elizabeth City, NC
    Asgard, thank you very much! Is there more to that by chance? That definitely helps! Does anyone know what they're using for 'matchmarks' on the driveshaft? Are they stickers that can be removed or grease pencil?
  5. May 24, 2010 at 9:05 AM
    LVTacoma
    LVTacoma Well-Known Member
    Having worked at several dealerships with family as service managers. Go to the GM of the dealership. Nothing more infuriating then some jack off suit and tie who probably doesnt even drive a Toyota telling you that you're wrong when clearly he didn't acquire that position by working on the vehicles he gets paid easily 6 figures to "service manage"
  6. May 24, 2010 at 9:12 AM
    brian
    Elizabeth City, NC
    You can be sure I'm probably going to do that. The vibes I'm getting are not as apparent as the bad u-joint was, so I can KINDA understand not feeling it unless you know the vehicle, but the fact that the zercs were out of line front and rear was the obvious sign, and he told me that only the middle zerc, the ujoint that was replaced was out of align and thats 'nothing to worry about' or something to that extent.
  7. May 24, 2010 at 9:15 AM
    brian
    Elizabeth City, NC
    The only marks I can find on my driveshaft is on the front, it appears the head of one bolt is 'blue' from a paint pen. Another bolt forward of it on the transmission is blue as well, looks fairly fresh. There are no marks on the rear driveshaft or rear axle.
  8. May 24, 2010 at 9:18 AM
    LVTacoma
    Just had mine replaced (last week) at the driveline shop in town. I avoid dealerships at all costs for these reasons. Hope this gets worked out and maybe get a free detail or two out of it ;)
  9. May 24, 2010 at 9:22 AM
    brian
    Elizabeth City, NC
    The only reason I take it in is because its warrantied till 107k. I could do all the work myself if I had to. No way in hell they are going to detail my truck either, I won't even let my wife touch the damn paint, she's done enough damage already! If they wanted to pay me back, they can paint my front bumper again! Stupid thing fades, looks pink after a rain.
