Has anyone ever mistake an intake manifold gasket leak for a blown head gasket ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kevtacos, May 6, 2025.
  1. May 6, 2025 at 10:23 AM
    kevtacos
    kevtacos [OP] Active Member
    kev
    I have a 2009 Toyota Tacoma 4.0 V6. I was just wondering if anyone has ever mistaken intake manifold gasket leak for a blown head gasket ? The miles on mine are 183k. Coolant was found in the cylinder but not sure which of the two is the reason. I’m going to do a tube test for the coolant to see if there’s combustion gases in it.
  2. May 6, 2025 at 10:33 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure how you could, there's no coolant running through the intake on the 4.0 so any coolant getting in a cylinder would have to come from the headgasket or a crack in the head itself.
    twblanset and Bishop84 like this.
  3. May 6, 2025 at 10:42 AM
    kevtacos
    kev
    what about the throttle body?
  4. May 6, 2025 at 10:56 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I've never seen a throttle body leak internally.
    Should be pretty easy to confirm a headgasket with a borescope and pressure on the cooling system, you can see the coolant dripping in the cylinder if there's a leak.
  5. May 6, 2025 at 10:58 AM
    Bishop84
    Bishop84 Well-Known Member
    Only way for coolant in the cylinder is through the cylinder head, block, or the gasket that separates them.
    Intakes with crossover coolant channels are gone with the dodo.
    Dm93 likes this.
  6. May 6, 2025 at 11:11 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There would likely be standing water (coolant) in the intake if anything upstream of the cylinders was leaking
