Has Anyone Had Luck Replacing the Secondary Air Pump w/ An Aftermarket Unit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TegoTaco, Nov 23, 2022.
  1. Mar 2, 2023 at 8:45 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Will the HP tuner work with the air pump completely removed or does it still need to be installed?
  2. Mar 2, 2023 at 8:56 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    HP tuner will just let you turn it off whether you chose to physically remove it all or not. But you’ll have to do it yourself. EPA is watching all the tuners out there (wink), so they will not disable emissions equipment for you.
  3. Mar 2, 2023 at 9:08 AM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    Got it, I think if I didnt need the space in the engine compartment I would go HP, that thing is sweet
  4. Mar 2, 2023 at 9:51 AM
    TireFire
    Olympic Peninsula
    Huh? I mean with HP tuners you can make more space than with the bypass kit. Remove ALL of it (@zippsub9 has a write up), install 2005-11 passenger valve cover & exhaust manifolds, then disable it in the ECM with the tuning software
  5. Mar 2, 2023 at 3:54 PM
    TACORIDER
    JAKE
    EAST TAWAKONI TEXAS
    The bypass eliminates the pump on fenderwell and thats the spot I need open
  6. Mar 3, 2023 at 12:05 AM
    TireFire
    Olympic Peninsula
    Dood! When I said remove ALL of it, I meant all, including the pump. Seriously, look up the write-up from the guy I tagged above.
  7. Mar 21, 2023 at 8:44 AM
    Mizzenmast
    Mizzenmast Member
    Michael
    2013 double cab long bed
    none
    TegoTaco[OP] likes this.
  8. Dec 4, 2024 at 11:45 AM
    leofrasson
    leofrasson Member
    Leo
    2011 Green Tacoma
    Hello, I recently performed the Uni Filter UP-107 mod that many recommend, and during the process, I unscrewed the base where the air pump is located. Coincidentally, the next day my car started making a terrible noise when I drive faster than 35 mph, and it also feels weaker. Is there a chance that I might have damaged my secondary air pump? I can't tell if the noise is coming from the engine or the wheels. When the car is in neutral and I rev the engine, it sounds normal, even at high RPMs.
  9. Dec 4, 2024 at 11:46 AM
    leofrasson
    leofrasson Member
    Leo
    2011 Green Tacoma
    Oh no, it just occurred to me, is it possible that debris or dirt could have entered my engine during the modification process?
  10. Dec 20, 2024 at 7:29 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I had this issue last week, check engine and trac off lights, dtc for "pump stuck off"... forgot code number. Checked internal pump filter, clean and intact. Powered pump directly from battery , ran but sounded weak. I ordered a new aftermarket pump assy from Amazon. I continued to get the code and recurring limp mode. The new pump arrived Wednesday and I installed. The new pump sounds much faster when on but it seems noisier in operation than the original pump. I have not had any further codes set. I took the rubber boot off the oem pump and found carbon brush dust all over the motor housing. I guess at 117k the brushes and commutator were about done. The pump seems to normally run about 10 seconds on cold start and about 2 seconds on shut down. It must also cycle while driving to verify operation and complete the emissions monitor cycle.
  11. Dec 29, 2024 at 7:52 PM
    leofrasson
    leofrasson Member
    Leo
    2011 Green Tacoma
    I just changed the oil, and my truck healed. She is running perfectly now, with no noise, and full power.
    She is awesome :D
