Has anyone had problems after installing the A/C drain mod?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by carlk, Dec 2, 2022.
  1. Dec 3, 2022 at 1:50 PM
    #41
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I did because it was inexpensive and didn't take up much time. Driving in the rain is slightly different since it's occasional and water will quickly run off the sides and bottom of the frame due to gravity. The AC line would constantly drip on the top of the frame causing it to always be wet (in my conditions with my use).
    Whether or not that would develop issues didn't bother me since it was such a simple and cheap thing to do.
    Lots of people who live along the Gulf coast or anywhere humid. Even during the winter, if you don't use AC your interior windows will fog up quickly.
    zoo truck likes this.
  2. Dec 3, 2022 at 1:55 PM
    #42
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I have those same issues at times in the summer here in the northeast. The humidity can be wicked.
  3. Dec 3, 2022 at 2:03 PM
    #43
    MGMDesertTaco
    :wave:
  4. Dec 3, 2022 at 2:18 PM
    #44
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    Had mine on since March 2016, no issues.
  5. Dec 4, 2022 at 9:04 AM
    #45
    86_MR2
    86_MR2 Swallow my tranya
    North Chicagoland
    2022 TRD Off Road M/T, Neil Armstrong Edition
    The “2 second mod”.
  6. Dec 4, 2022 at 5:29 PM
    #46
    HankHeel
    HankHeel Active Member
    Philadelphia
    2021 TRDORDCLB
    As others have said, your extending an existing drain that is gravity fed. Nothing negative could occur.
  7. Dec 5, 2022 at 8:51 AM
    #47
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    anyone who dislikes humidity.
  8. Dec 5, 2022 at 8:53 AM
    #48
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, RP-342 lasts a bit longer but it's nastier to apply. i wore a respirator.
  9. Dec 5, 2022 at 9:08 AM
    #49
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    piece of garden hose with a screen on the bottom... been on for around 13 years with zero issues.
  10. Dec 5, 2022 at 9:16 AM
    #50
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    "Occasional" rain is caused by moisture saturated air which cause even more corrosion damages than just water. Cause the exposure time
  11. Dec 5, 2022 at 9:33 AM
    #51
    TacoTrigger16
    TacoTrigger16 Well-Known Member
    Central Valley California
    2022 TRD OR 4x4 DCSB Super White
    Armor: RCI Plated 20 Degree Sliders RCI Full Skid Plates Steel RCI Fuel Skid RCI Rear Diff Skid SNS Designs ABS Guards Front Bumper: C4 Overlander with Full Hoops C4 Front Bumper Frame Support Brackets Bed: Total Chaos Bed Stiffeners Cali Raised Bed Light Kit Toyota Bed Mat Alu-Cab Contour Canopy Blue Sea 5025ST Fuse Block Blue Sea 4363 Switch Panel Victory 4x4 Front Bed Molle Panel Mountain Hatch Tailgate Table 3.0 Fire Extinguisher Shovel Axe Fatmax Extreme Lighting and Electrical: PowerTrays Essentially BantamX Spod Bantam X w/ Touchscreen Baja Designs 30” S8 Light Bar Driving Combo Baja Design Squadron Sport Diving Combo Baja Design Squadron SAE Fleece All Lights On Engine: K&N Drop In Air Filter Mishimoto Intake Hose Toyota Air Accelerator Toyota TRD Oil Cap Toyota TRD Radiator Cap ECGS Bushing SDHQ Terminal Kit Fumoto Engine Oil Drain Valve AC Drain Mod Exterior: De-Badged Black Tacoma Tailgate Letters Heritage Badge In Black/Grey/White AVS Rain Guards AVS Aeroskin Hood Protector Lftd Customs Taco Sauce Gas Cap Holder Tacoma License Plate Frame Black Sylvania License Plate LED Lights R4T Bumper Caps Meso Customs Headlight Trim Plate Meso Customs V5 Ultimate Turn Signals SDHQ Ditch Light Mount Rago Fab Antenna Mount Interior: Desert Does It Seat Jackers & MMP K&N In Cabin Air Filter Matte Black Steering Wheel Emblem Meso Customs Red Push To Start Meso Customs Vent Rings SW Meso Customs Climate Control Rings SW Meso Customs Interior Chrome Delete SW Meso Custom Minimalist Key Fob V2 SW Meso Customs Extended Fuse Cover AJT Designs Door Handle Covers Z Precisions Cup Holder Midland MXT275VP4 Yodaverse Interior LED Kit Yodaverse Center Console Organizer TacoMods Radio Knobs w/ Backlighting Headrest Paracord Grab Handles SOG Rapid Rescue Dongar Technology Mirror Adapter Garmin Dash Cam Mini 2 Baby Toyoda Square Center Console Insert WeatherTech FloorLiner HP Grey Expedition Essentials 3TPAM Ram Mount Accessories GoGettaGrip Shifter Knob Magnetic Mic Patches Suspension Lift: DuroBumps Front Bump Stops Icon Billet UCA’s Delta Joint All-Pro Sway Bar End Links Marlin Crawler HD LCA Frame Brace Bison Offroad Cam Stop Kit Total Chaos Cam Tab Gussets Total Chaos Cab Mount Chop Plates Total Chaos Spindle Gussets W/ Sway Bar Accutune Fox 2.5 DSC Front Shocks Accutune Fox Tundra 2.5 DSC Rear Shocks Accutune 2.5” Bump Stop & U Bolt Flip Deavers U402 Stage 1 Yota Mafia Rear Extended Brake Lines 24” ARB Carrier Bearing Drop Kit FK29 Archive Garage Hammer Hangers Archive Garage 3.6 Shackles Archive Garage High Clearance Cross Tube Wheels and Tires: SCS F5 16x8 -25 Offset 3.5 BS Gunmetal Mickey Thompson Baja Boss M/T 285/75R16 Gorilla M12x1.5 Lug Nuts ET Liftd Customs Leashed Valve Stem Caps Winch: Warn VR Evo 10-S Warn Wireless Hub Factor 55 1” Fairlead Factor 55 Rope Guard Factor 55 UltraHook Gray Tandem Offroad Control Box Mount LambTek Innovation Switch Bracket Kit Blue Sea Switch Recovery: Factory 55 HitchLink 2.0 Warn Epic Shackle x2 ARB Tree Saver 16’ Special Thanks to: Sibi Built for the lift installation. Tiny Rig Co for the Alu-Cab and installation. Accutune for the Fox Shocks with Adventure Tune. Baja Designs for lighting. C4 Fab for the front bumper. RCI for sliders and skids.
    For Central California. Lots of 100 degree days here. Did the mod when the truck was new this year. No issues. Had a 2016. After 100,000 miles it was starting to show a little rust.
  12. Dec 5, 2022 at 9:35 AM
    #52
    6 gearT444E
    Deep South
    Herculiner Hootus
    Why not just move to a less humid place then. Seems easier than putting on a drain hose mod.
    TacoTrigger16 likes this.
  13. Dec 5, 2022 at 10:22 AM
    #53
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    :spending::duh:
  14. Dec 5, 2022 at 10:26 AM
    #54
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Nope. I mean, as long as you don't have the hose tied to a hot pipe, there is absolutely nothing to worry about. It is an easy mod, and if you use AC a lot, it is well worth it. Many people who have only had their trucks for a few months and used AC, noticed the beginnings of rust in that short of a time. So this one is a no-brainer to do...
  15. Dec 5, 2022 at 10:30 AM
    #55
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Me to...My 2009 has a metal tube on it and its drips on the exhaust...every drip after it cuts off i can hear it sizzle
  16. Dec 5, 2022 at 1:46 PM
    #56
    zoo truck
    None
    I found rp-342 no stinkier than fluid flim...actually it smells better than FF. I just wore coveralls, and a pair of safety glass's when i did my truck with rp-342, and lived to tell about it. I'm still alive, and breathing over 2 years later. Lots more nastier stuff out there imo.
  17. Dec 7, 2022 at 8:51 AM
    #57
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I would disagree. Yes occasional moments the condensate drips down while stopped at a red light for example , then gets it gets blown around and dries as you drive . Its not a constant stream of water. Its a dribble that disperses . In New England I use the ac a few weeks a year. Theres much more water volume when driving in the rain and its definitely more than occasionally where I live. Not to mention driving in the winter months.
