Has anyone had to replace a clutch yet?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by geekyadam, Sep 20, 2019.
  1. Sep 20, 2019 at 9:17 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    All i can say is good luck and if you use the dealer to replace it, hopefully they will find out why this happened, so at least the warranty will cover it .
    Curious to know what caused it, let us know.
    shakerhood likes this.
  2. Sep 20, 2019 at 9:25 PM
    bzzr2
    bzzr2 Well-Known Member
    This was an issue with the 4cyl clutches, not sure about the 6cyl. I bad the LUK junk and the pressure plate was defective. The 'fingers' on the plate were all warped, easy to spot once out. Hope they warranty this for you OP.
    Jeffch[QUOTED] likes this.
  3. Sep 20, 2019 at 9:31 PM
    suaveflooder
    suaveflooder Well-Known Member
    2021 4Runner Venture
    Lots of factors to consider. I know it happens on all cars/trucks (low mileage clutch failure), but I can tell you now, they are gonna find a reason to blame you on a wear item. Even if there is an issue
    AKGSD likes this.
  4. Sep 21, 2019 at 4:28 AM
    geekyadam
    geekyadam [OP] Game Master
    Adam
    Northern Virginia
    17 SPT MT DCSB
    OME lift, 3leaf AAL, uniball UCAs, 3° shims, CV bushing, U-bolt flip + Superbumps, sway bar relocate, Cooper Discoverer AT3 XLT 33s, cosmetics
    Yeah my thoughts too. Really pisses me off
  5. Sep 21, 2019 at 9:34 AM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    Had 180 k kloics on mt 2nd gen and clutch was original and working fine
  6. Sep 21, 2019 at 9:40 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Had mine replaced very early on. I think at around 6k miles, I can't even remember correctly. Except my clutch wasn't slipping. I think mine was dragging a little bit because I was hearing bearing type noise and some of shifts were notchy and 1st would actually be harder to pull out of gear with the clutch all the way to the floor. Was told it was an overtorqued pressure plate. Was covered by warranty. Thank God!
    geekyadam[OP] likes this.
  7. Sep 21, 2019 at 9:53 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    That really sucks OP. I was looking hard at a OR MT but then saw that they don’t make them in LB. I was debating as I like MT paired with the options of the OR (plus it’s like a theft deterrent since most can’t drive them lol). I then found multiple posts on here as I was researching with premature clutch failures. It’s very likely a factory issue affecting a small percentage, you might get them to cover it if you deal with corporate and are persistent. Clutch should last at least 100k even with hard use. The few posts that I saw made the decision easier to go with the AT since I was pretty set on LB. I wish you luck. Start sending emails to corporate.
  8. Sep 21, 2019 at 10:48 AM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    OP,
    For now while waiting on the dealer's response I would call these guys and ask them their take on the 3rd Gen OEM clutch, they do offer two redesigned clutch assys:
    https://www.urdusa.com/urd-stage-2-clutch-2gr-fks-3-5l-v6-w-6-speed-transmission/
    https://www.urdusa.com/urd-stage-3-clutch-for-2gr-fks-3-5l-v6-w6-speed-transmission/
    You might want to contact TW member Trident904 as well, he's well versed in Toyota clutches.
    https://www.tacomaworld.com/members/trident904.131875/
    If the warranty won't cover your OEM clutch I would seriously consider the URD clutch and maybe their flywheel?
    geekyadam[OP] and Canadian Joe like this.
  9. Sep 21, 2019 at 10:51 AM
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    I have a 2016 OR MT 158500 km ( 99000 miles) no issues,no noticeable change since new.
    There must be some defect.
    TeecoTaco likes this.
  10. Sep 21, 2019 at 1:07 PM
    Desolate
    Desolate Well-Known Member
    Feels like mine might be on the way out. Probably from towing heavy loads. Just hit 51k
    AdventureKid and geekyadam[OP] like this.
  11. Sep 22, 2019 at 6:48 AM
    geekyadam
    Adam
    Northern Virginia
    17 SPT MT DCSB
    Lucky you! If you wouldn't have had it addressed til a few more miles they might have tried to blame normal wear.
    Yeah I'll do that. I have an anti-theft sticker on my truck with a 6spd diagram. ;)
    Yeah I'm going to try pestering corporate and try to get someone on the phone but not sure if I'll make any progress, so probably spending thousands on this work myself. Already planned to bump to a stage 3 and the heavy duty flywheel. If I replace with another OEM clutch, there's no way I'm keeping the truck (I'm not replacing the clutch every two years no way). Only way I'm keeping it is if the clutch is going to last and a stage 3 should be able to take any normal abuse a regular clutch can.
    specter208[QUOTED] likes this.
  12. Sep 22, 2019 at 7:28 AM
    Connecticut_Tacoma
    Connecticut_Tacoma Well-Known Member
    Old Greenwich, CT
    2016 Tacoma TRD SPORT 6-speed Access Cab
    Mine is in a shop getting its clutch changed as we speak; I have a thread on it. I’m at 50k miles and I’ve driven only manuals my entire life (20 years of driving now). I did buy the truck with 25k miles on it so who knows what the previous owner did.
    I’ve never had a clutch go this fast. I did have an Audi clutch go once but that was over 100k miles.
    I went with the URD clutch. I should have it back on Monday so I’ll post a review. I also had them install the URD short shifter while they are at it. I’ll post a review After a week once I receive the truck back. Hopefully the shop runs into zero problems. He’s charging me 750 for the install and 150 to resurface the flywheel. I bought my own clutch so that’s not included in there.
    The shop did say that a ton of my bolts were rusted to hell. He’s going to use marine grade nuts and bolts they don’t rust (he mentioned the driveshaft bolts and exhaust pipes etc).
    geekyadam[OP] and specter208 like this.
  13. Sep 22, 2019 at 9:52 AM
    hikerduane
    hikerduane Stove & lantern collector, retired
    Duane
    Meadow Valley, Jefferson USA
    '16 Blazing Blue Pearl TRD Sport AC V6 manual, tow pkg
    RCI sliders fuel tank skid plate, Softopper, tailgate insert
    My 1992 4 cyl had 270,000 when I sold it. Clutch worked fine, buyer was surprised I had never replaced it. He buys and sells Toys.
    Duane
  14. Sep 22, 2019 at 10:56 AM
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    What's the best indicator for a slipping clutch? Driven manual all my life and never had one malfunction yet..
  15. Sep 22, 2019 at 11:40 AM
    #35
    Connecticut_Tacoma
    Old Greenwich, CT
    for me it was only in higher gears on the highway. So let’s say you’re in 5th gear and all of the sudden you gas the car, if the rpm shoots up without the truck actually moving any faster then your clutch is slipping.
  16. Sep 22, 2019 at 12:00 PM
    #36
    specter208
    California
    I heard it easy to shock the load the tranny with performance clutches in passenger vehicle use.
  17. Sep 22, 2019 at 12:06 PM
    #37
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    I replaced mine at 40k due to the throwout bearing taking a shit. Went with the URD stage 2 and heavy flywheel. I also did the accumulator delete at this time. Made all the difference in the world afterward.
  18. Sep 22, 2019 at 12:15 PM
    #38
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    You never know how a previous owner drove the vehicle. I bought a Sportster with only 250 mikes on it and found that the clutch was burnt. Some people just can’t drive MT’s.
  19. Sep 22, 2019 at 12:34 PM
    #39
    eon_blue
    Azusa, CA
    RPMs go up but the engine speed doesn't, or does very slowly. That's a slipping clutch.
    rubiconjp[QUOTED] likes this.
  20. Sep 22, 2019 at 12:35 PM
    #40
    Trident904
    Brian
    17 4Runner TRD OR
    That and some people think that trucks are made for racing.
    whatstcp and su.b.rat like this.
