Has anyone here actually driven a 4th gen SR?
Discussion in '4th Gen. Tacomas (2024+)' started by PanzerDivisionBlack, Jul 16, 2024.
  1. Jul 17, 2024 at 3:23 PM
    #41
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Cheaper to manufacture, vs having a completely different engine with 100% different components (i.e. 2.7L).
    Now why buy one? That's a good question.
  2. Jul 17, 2024 at 3:35 PM
    #42
    linuxpickup
    linuxpickup Well-Known Member
    2024 OR MT
    I'm confused. The SR MT and higher trim MTs are all rated for the same HP - 270. The higher trim MTs have the same engine oil cooler as the autos, correct? If so, doesn't that mean the SR MT, rated for the same HP, has the same engine oil cooler? So how does the engine oil cooler (as opposed to the presence or lack of a tranny cooler) explain the detuned 228 vs 278 difference between the SR and higher trim automatic trans models? Or maybe only the SR auto lacks an engine oil cooler while the SR MT has one?
  3. Jul 17, 2024 at 5:47 PM
    #43
    Schlappesepple
    Joe
    2020 4Runner ORP
    They're two different things: it it's like the 2nd and 3rd gens, the oil cooler is like part of the towing package, to keep oil temps down under load. So not directly related to the engine's horsepower.
    Vitamins likes this.
  4. Jul 17, 2024 at 5:53 PM
    #44
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    I bet the detuned engine last longer. It should do pretty well dragging a 2 or 3 thousand pounds of things like lawnmowers and tools.
  5. Jul 17, 2024 at 6:57 PM
    #45
    Mexmeno
    Mexmeno Well-Known Member
    Ontario Canada
    23 TRD Off-road
    Unfortunately in Canada the SR models with the detuned engine aren’t even available in the lineup configurator.
  6. Jul 17, 2024 at 7:41 PM
    #46
    PanzerDivisionBlack
    PanzerDivisionBlack [OP] Well-Known Member
    What engine do you get then with the SR?
  7. Jul 17, 2024 at 7:55 PM
    #47
    Mexmeno
    Ontario Canada
    23 TRD Off-road
    The SR is not available. The lowest price Tacoma is an SR5 with the regular 2.4 turbo and a 6foot box.
  8. Jul 17, 2024 at 9:33 PM
    #48
    linuxpickup
    2024 OR MT
    I get that, but I don't understand why there no difference between MTs in HP or towing yet the SR AT is significantly less? Obviously there isn't a concern with respect to MT trans temp under load like there is with an auto, but wouldn't the MT SR be derated as well if it's missing the engine oil cooler? Sorry if I'm being dense. I'm not sure which 4th AT trims, if any, have a trans cooler.
  9. Jul 17, 2024 at 9:34 PM
    #49
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I don't think any do.
  10. Jul 18, 2024 at 5:46 AM
    #50
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    i have a 4th gen manual trans SR and a 3rd gen auto SR.
    the 4th gen for sure has more torque once boost kicks in.
    low rpms before boost hits is pretty abysmal though.
    Old goat1914 likes this.
  11. Jul 18, 2024 at 7:11 AM
    #51
    Sagebrush
    Gens 1, 2, 3, and 4
    Doesn't the turbo kick in at 1700?
  12. Jul 18, 2024 at 7:25 AM
    #52
    Blueberry.Taco
    Ryo
    SE MI
    I don't know how much torque limiting / boost by gear is built in but doesn't feel like much in the first 2 gears.
  13. Jul 18, 2024 at 7:43 AM
    #53
    Steves55
    Steves55 Well-Known Member
    Palm Desert, Ca
    2023 TRD Off Road
    Couldn't you add an oil cooler after purchase? Either the factory or aftermarket?
  14. Jul 18, 2024 at 7:56 AM
    #54
    Schlappesepple
    Joe
    2020 4Runner ORP
    You wouldn't even think to add one if the higher trims didn't have one.
    These are water cooled engines, and no one is going to be working the base SR hard enough to need one. I don't know the full rationale for adding one for the towing package on the previous gens, but I have a feeling they are overkill for most people (like the external transmission cooler they dropped in later years).
    Basically, if you need one, the base engine SR is the wrong truck for you anyway. And honestly, if you're looking for a hardworking, dedicated tow vehicle, no Tacoma is the right truck for that.
    Sagebrush likes this.
  15. Jul 18, 2024 at 8:23 AM
    #55
    ericin1984
    ericin1984 Well-Known Member
    2023 TRD OR Auto
    The SR is literally the only trim that fleet/contractor buyers would be interested in, yet it has a lower tow rating than my Subaru. Toyota is just shooting themselves in the foot. All the hardware is already there. They had no reason to design a special detuned, low tow rating vehicle.
  16. Jul 18, 2024 at 8:26 AM
    #56
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    The SR is way more powerful than it ever has been, the 2.7 wasn't exactly a powerhouse and Toyota sold plenty of them to fleets.
    About that... Fleets aren't buying SR's to do hotshot towing. They're using them for stuff like in-town parts delivery and services. I see lots of SR's being run by Orkin.
    Schlappesepple and BabyBilly like this.
  17. Jul 18, 2024 at 8:26 AM
    #57
    Sagebrush
    Gens 1, 2, 3, and 4
    Well... they sell more vehicles than any other manufacturer in the world, so they're not limping too badly.
  18. Jul 18, 2024 at 9:33 AM
    #58
    Schlappesepple
    Joe
    2020 4Runner ORP
    Most of those fleet vehicles used to be 5-lug trucks too, which should tell us everything we need to know about that market.
    abou824[QUOTED] likes this.
  19. Jul 18, 2024 at 11:00 AM
    #59
    ericin1984
    2023 TRD OR Auto
    The difference is that the 2.7L models had a reason for existing. They were less expensive to build, and got slightly better gas mileage than the V-6. The 4G SR took extra effort, with no apparent cost savings, to build a less capable truck. It's dumb. If I was looking for a work truck to tow mowing equipment and lumber around, I'd get a Frontier S.
  20. Jul 18, 2024 at 11:06 AM
    #60
    Bitflogger
    Bitflogger Well-Known Member
    2024 TRD OR long bed
    Maybe my wife's observations and sensitivities would help.
    I thought all the models made some amount of sense against each other for their price points and features. My wife was very quick to not like the less than OR or Sport seats and coil springs. I thought SR and SR-5 were still improvements on prior generations.
