Has Anyone Here done Rear Axle Seals on a 3rd Gen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RWhiz, Jan 20, 2025.
  1. Jan 20, 2025 at 2:35 PM
    RWhiz
    RWhiz [OP] New Member
    Rob
    2017 TRD Off Road
    Sorry if this has been covered, as I've searched I've seen quite a few 2nd gens getting their rear axle seals done and I'm not sure if they are the same. I've got a leak on the drive's side so I'm looing at doing this if it's not too hard. TIA
  2. Jan 20, 2025 at 2:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It’s the same process.
    Except the torque numbers for the nuts holding the axle in changed. IIRC?
    RWhiz[QUOTED][OP] likes this.
  3. Jan 20, 2025 at 2:41 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    The seal part number and all the associated wheel bearing hardware is the same as 2nd gen.
    If you have a leak, just changing the seal probably won’t fix it long term. The seal seals to the wheel bearing retainer collar, and I would expect the cause of a leak is a groove in that collar. Replacing that collar would require a press to install the new. So I imagine it will be more involved than just replacing the seal. Not a hard job but a decent bit of work and required tools.
    RWhiz[OP] and Steves104x4 like this.
  4. Jan 20, 2025 at 2:43 PM
    TnShooter
    Deogee
    STOCK
    I’ve found that a lot of time, the rear breather is stuck closed.
    This builds up pressure in the differential and it has to go somewhere.
    Which is out the axle seal.
    Always, change, or at a minimum, inspect the breather when doing an axle seal.
    RWhiz[OP] likes this.
  5. Jan 20, 2025 at 2:49 PM
    BLtheP
    Plano, TX
    It’s worth throwing a new one on, but they’re difficult to just inspect. They give the illusion of being bad because they hold in pressure by design. But throwing on a new one isn’t a bad idea at all.
  6. Jan 20, 2025 at 10:14 PM
    EK99civic
    EK99civic Well-Known Member
    Danny
    16' Tacoma TRD O/R
    jdjones, bigoldbeef, Akguy and 2 others like this.
  7. Jan 21, 2025 at 8:04 AM
    Vinman02
    Vinman02 Well-Known Member
    Vince
    2019 Tacoma TRD
    Levelling kit
    Was just going to suggest the same thing. I’ve my Jeeps rear axle actively drip oil from the pinion seal and once I cleaned the vent, zero drips and it didn’t even sweat from the pinion afterwards
    TnShooter[QUOTED] and RWhiz[OP] like this.
  8. Jan 22, 2025 at 8:52 AM
    RWhiz
    Rob
    2017 TRD Off Road
    That is a great video, the job looks kinda OK but with the press and special axle tool I might look into subbing out that work to a machine shop. I should be able to bring them the axles and then have them press off the retainer and install the new Koyo bearing assembly and retainer.
  9. Jan 22, 2025 at 9:06 AM
    EK99civic
    Danny
    16' Tacoma TRD O/R
    RWhiz[OP] and BLtheP like this.
  10. Jan 22, 2025 at 9:08 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Def need a 20+ ton press to break em free
  11. Jan 22, 2025 at 9:11 AM
    EK99civic
    Danny
    16' Tacoma TRD O/R
    Did mine with 20ton harbor freight special, no issues at all
  12. Jan 22, 2025 at 10:11 AM
    BLtheP
    Plano, TX
    Damn, wish I had known about that tool. I bought a more expensive one on Amazon that didn’t fit in a HF press. Had to buy another press with a bolt together press shelf in order to use that tool.
  13. Jan 22, 2025 at 12:09 PM
    RWhiz
    Rob
    2017 TRD Off Road
    Thanks for the advice. I have access to a press but the logistics would be weird to get the axles to the press (without my truck!) and back. I've heard that there is only one decent tool for this job so thanks for the link to the right one.
  14. Jan 22, 2025 at 12:34 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I've used a couple different tools and a 20T press wasn't enough to push it out. I had to heat up the bearing with a torch before it would pop free and made a few of us poop a little. Very scary if you have a really tight race. Otherwise they just pop right off and you can be done in less time than it takes to bleed the brakes.
  15. Feb 3, 2025 at 9:14 PM
    EK99civic
    Danny
    16' Tacoma TRD O/R
    Oh shoot, I meant I used a 20ton press, my bad for the incorrect info
