Has anyone here replaced control arm bushings themselves
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Jul 18, 2018.
  1. Jul 18, 2018 at 6:30 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I'm swapping out UCA's, lower ball joints and shocks so it would kill me to not replace the LCA bushings while I'm in there. However, i hear nightmare stories about attempting this.
    I have an electric impact wrench and will have a ball joint press. Will these two not suffice for removing & installing bushings?
  2. Jul 19, 2018 at 7:51 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    yep that will get the job done. to get them out, i found the easiest way to do it is jus to burn them out. hit it with a torch and let it burn itself out. just do it outside with a facemask because its guaranteed cancer. the new ones go in real easy with a press. sometimes u have to put a little bit of grease around them so they dont stretch or pinch up. the worst part is the smell of the burning rubber.
  3. Jul 19, 2018 at 7:59 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  4. Jul 19, 2018 at 10:09 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Thats do-able. Does the outer metal sleeve stay in the control arm after you burn them out though? Or did you replace the bushings with one that doesn't have the outer sleeve on it?
  5. Jul 19, 2018 at 10:44 AM
    GHOST SHIP
    GHOST
    Post #2068 here:
    https://www.tacomaworld.com/threads...-and-adventures.362772/page-104#post-12685176
    And replace with white line PU bushings. Best upgrade you can do while you have everything apart.
    Whiteline W53312 Front Control Arm Bushing https://www.amazon.com/dp/B0070I9I12/ref=cm_sw_r_cp_api_c2muBbQ2B7FZ2
  6. Jul 19, 2018 at 10:44 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Drill the out .easy peasy
  7. Jul 19, 2018 at 12:10 PM
    617mike9c1
    617mike9c1 Well-Known Member
    Newton, MA
    2008 DCLB Sport 4wd
    A little of this and a little of that
    In the same boat now trying to remove the OEM bushings. Tried the torch and bottle jack method and the bushings still woudn't budge. Guess I need to apply more heat?
  8. Jul 19, 2018 at 12:15 PM
    lynlan1819
    Tacoma
    Lifted
    Drill a bunch of holes in the rubber,and pop it out,simple.
  9. Jul 19, 2018 at 12:18 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Ive heard of others having success using this method
  10. Jul 19, 2018 at 12:18 PM
    617mike9c1
    Newton, MA
    2008 DCLB Sport 4wd
    I'll give that a shot this weekend. How did you end up removing the bushing sleeves? Sacrifice a screwdriver to pry it out?
  11. Jul 19, 2018 at 12:19 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Ive looked at these, damn they're expensive! I am on the street 90% of the time, do you think these are necessary?
  12. Jul 19, 2018 at 12:55 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I just installed those Whiteline bushings in the Amazon link above. They do transmit a bit more vibration into the truck but they are SOLID. The truck drives and handles a good bit better and all the creaks/pops/clicks I had when turning and such are completely gone. My OEM bushings were DONE.
  13. Jul 19, 2018 at 1:23 PM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    When I did my UCA bushings on my LR UCA's, I just cut the flanged part of the bushing off and then tapped the whole bushing through with a hammer and a chunk of wood.
    Other than that, I would suggest drilling drilling the bushing out.
  14. Jul 19, 2018 at 1:26 PM
    lynlan1819
    Tacoma
    Lifted
    Easiest way of all,and no mess or burned arms.
  15. Jul 19, 2018 at 2:49 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    What brand of bushings seem to work? I've heard bad things about Moog and whiteline is unneccesary for me. What's the word on Mevotech?
  16. Jul 20, 2018 at 12:56 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Hey man, did you ever get the sleeve out? I'm wondering how it's best done
  17. Jul 20, 2018 at 1:00 PM
    617mike9c1
    Newton, MA
    2008 DCLB Sport 4wd
    Haven't tried yet. Will give it a shot tomorrow.
    My plan is to weaken the rubber bushing with a drill bit and burn the crap out of it. It probably will get messy but it is what it is. I'll update the thread when I have some news.
