Has anyone installed a oil catch can in a 2019 Tacoma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD Larry, Aug 12, 2019.
  1. Oct 9, 2019 at 10:49 PM
    #241
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    All my sbc race engines I've built have used oil catch cans , pan evac set ups or vaccuum set ups for 20 plus years . With any of these oil control devices you can run better rings which aids in better ring seal
    Just the benefit of using a oil puke tank set up can do wonders to an engine
    Such as ......
    Stop oil reversion into the intake manifold
    Oil residue build up on intake /exhaust valves
    Removes oil build up and carbon build up on the piston face
    Big tall dave, badkids and 2016Taco like this.
  2. Oct 10, 2019 at 4:54 AM
    #242
    2016Taco
    2016Taco Well-Known Member
    Greater Toronto Area
    2016 Blazing Blue TRD Sport Upgrade DCLB 4X4
    Intelligent answers Woodrow. You wrote "The oil is supposed to be there, you expect it right? Not so much the water." in that post #238. You are right in that the oil is there as it's from the inherent design of the engine, but its not suppose to go into the intake manifold and manufacturers do their best to keep it out. Toyota has to duel injection to try to clean it out as they don't want it caking the valves.
    you could be onto something in your situations
  3. Oct 10, 2019 at 5:42 AM
    #243
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I have. The bearings gave up before the gunk caused problems. With newer engines and better gas, it's less of an issue.
    It's great you have justified the mod to yourself, most people will never know the difference... they will see ZERO impact of this mod other than the lightening of the wallet. If you or anyone else with this mod can honestly say "Yeah, I probably won't ever notice the results of this mod, but I feel better knowing there is less stuff going through my engine", then great. It's like changing your oil at 3,000 miles.
    MtnFisher likes this.
  4. Oct 10, 2019 at 6:34 AM
    #244
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    You remind me of Smitty. LOL.
    “To each their own”, or “Whatever helps you sleep at night” would have wasted much less of your time.
    Big tall dave, boston23 and 2016Taco like this.
  5. Oct 10, 2019 at 7:09 AM
    #245
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Has Toyota ever said that was the reason for both PI and DI? I can't find anything saying that for them or Ford. Both say it's because in some cases PI is better and some DI is better. I doubt both spent the extra money to do dual injection to stop a supposed carbon build up issue that won't happen under warranty. Washing of the valves may be a side benefit but not the reason for both PI and DI.
    https://www.tomorrowstechnician.com/toyota-d-4s-port-fuel-or-direct-fuel-injection-why-not-both/
    "And, the port fuel injectors are not there to clean the intake valves; these injectors work to provide fuel to the engine. Both sets of injectors work together for the best possible fuel mixture in the cylinder."
    Big tall dave and US Marine like this.
  6. Oct 10, 2019 at 7:11 AM
    #246
    2016Taco
    I think Toyota has published about the cleaning cycle of this engine which uses port injection to try clean the valves. They may have not said specifically the cleaning was for the valves but what else could it be for? You are squirting gas at the valves.
  7. Oct 10, 2019 at 7:29 AM
    #247
    2016Taco
    I'm sorry you could not find anything, Google was my friend and I found this:
    https://www.wardsauto.com/technology/toyota-advances-d4s-self-cleaning-feature-tacoma
    and this:
    https://www.quora.com/Does-Toyotas-...-other-manufacturers-followed-Toyotas-example
    Your article is valid and maybe the Wards one is as well? Obviously some different types of info out there.
  8. Oct 10, 2019 at 7:55 AM
    #248
    RX1cobra
    19 OR
    Both of those articles are about cleaning the DI injectors not the valves. They can run the clean cycle (on the DI system) because they have the supplemental PI to cover the fuel needs. Nothing about the PI being used to clean the valves. The cleaning cycle is for the DI system.
    "Carbon is inherent in a hydrocarbon fuel, and will always be created when it is burned, and therefore will always be an issue in engines that run it. Particularly those that place injectors in the combustion chamber."
    “When you go into a hot-idle situation, the system is going to look at the time that it ran, the number of cycles the injectors went through, the temperature of the injectors and then it goes into a self-cleaning mode,” Sweers says. “Because we have the port injection, I can continue idling the engine without having any side effects.”
  9. Oct 10, 2019 at 9:19 AM
    #249
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    Seems cool, should have done it on my old Volkswagen GTI. Don't think I'll bother on this engine unless I'm really bored and want to spend $30 and an hour of my time.
  10. Oct 10, 2019 at 9:50 AM
    #250
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
  11. Oct 10, 2019 at 10:23 AM
    #251
    2016Taco
    Hey everyone, I posted a video of how I did mine: Please no debating whether you need it or not.
    This is if you decide for yourself that you want one. This is how I installed mine. I have an auto as my truck with the DCLB was only available with an auto so I had no transmission choice. Someone who watched the video alerted me that the bolts holes I used are for the manual. I'm going to try to figure something out for the manual to get around the clutch master cylinder. Is there anyone on here that can send me some pics of there clutch master cylinder and its dimensions? Maybe hold a ruler to the height and take a few photos of different angles and give me permission to use that picture in a video? This way we can help each other out?
  12. Oct 10, 2019 at 10:26 AM
    #252
    Woodrow F Call
    Colorful Colorado
    It's a mod that creates risk for very little (if any) return for that risk.
    Very few people should even think about doing this. Heck, I work on my own stuff. I built my first engine before I had a drivers license and I don't see the value in it. You just don't get much for the dollars and time to own it.
  13. Oct 10, 2019 at 10:32 AM
    #253
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    how is this discussion still going on? who knew "catch can" is tantamount to discussing abortion at thanksgiving dinner?
    GreyBaldTaco likes this.
  14. Oct 10, 2019 at 10:33 AM
    #254
    piff
    Minnesota
    Bone stock baby
    Watched your video. Very informative and quality content. Nice work.
  15. Oct 10, 2019 at 10:34 AM
    #255
    2016Taco
    Much appreciated and thanks
  16. Oct 10, 2019 at 10:36 AM
    #256
    2016Taco
    Oh Crap, I forgot to post the link. Here it is for anyone that is interested. Please keep in mind this is what I did and by no way am I telling anyone what to do. It's just what I did.
    https://www.youtube.com/watch?v=QoJ05ujFAvY
    Big tall dave and badkids like this.
  17. Oct 10, 2019 at 10:37 AM
    #257
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Damn people are getting salty about these catch cans. Id run one if i knew how to install. But fuck it imma just change my full synthetic oil every 5k.
    2016Taco and badkids like this.
  18. Oct 10, 2019 at 10:39 AM
    #258
    badkids
    im afraid to add one to my vehicle for fear or being ridiculed by an online helpful community of common vehicle owners.
    2016Taco likes this.
  19. Oct 10, 2019 at 10:40 AM
    #259
    2016Taco
    Well said
  20. Oct 10, 2019 at 10:41 AM
    #260
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Why do people feel the need to tell people what they can and can not discuss on an online discussion board?
