Has anyone installed a Pioneer Z110BT?
Discussion in 'Audio & Video' started by dk6487, Feb 11, 2010.
  1. Feb 11, 2010 at 8:55 PM
    dk6487
    dk6487 [OP] NorCal Member
    David
    Novato, CA
    08 Silver 4X4 TRD Sport w/ Tow Pack
    Pioneer Z110BT Nav/DVD H.U., Sub Box by Mr. Marv w/ amp and 10" Sub, Rear-Leaf TSB, L.E.D. Guage Mod, 3" OME Lift Kit w/ 885, Total Chaos UCA's
    I'm looking for any tips, hints, or ideas to make my install easier this saturday.:D
  2. Feb 11, 2010 at 11:07 PM
    jaysly
    jaysly Member
    Corpus Christi
    10 PreRunner TRDsport
    Just curious as to why you chose the Z110BT when the new x920BT will be coming out and looks to be pretty cool? I am currently debatting between the two. If you get a chance go to the Pioneer website and watch the short video on the x920BT.
    Be sure and take some pictures because I am really interested in how it turns out.
  3. Feb 12, 2010 at 7:26 AM
    TREY4x4
    TREY4x4 Well-Known Member
    Trey
    Dacula, GA
    2010 TRD OR 4x4 Double Cab
    Bilstein 5100's front/back set at 1.75", Pioneer AVIC110-BT head unit, JL 6x9 front and Alpine 6.5 rear, OEM bed mat, Weathertech floor mats, OEM sill protectors, Window tint, N-Fab side steps
    I just installed this unit 2 weeks ago. Install went smooth and everything worked first time. Best advice I can give is to take you time. I soldered/shrink wrapped all my connections (including the SWI-PS and bypass mod) the night before and again took my time to make sure everything was wired correctly and to make it as neat as possible.
    There really is nothing special about the install, although it's really tight behind the HU. Are you installing additional modules (ie XM, HD radio, etc)? I purchased the HD radio module, but didn't install it yet. I wanted to make sure everything worked first and just ran out of time that day. I am going to install it in the middle console within the next few weeks, along with an amp and sub.
    Here's one thing I did find that made the install easier. At first I didn't remove the glove box and tried to fish the GPS cable and BT mic behind it and up through the passenger side dash. It became too frustrating and decided to take out the glove box and try. I was surprised how easy it came out and the install after that was a piece of cake.
    One more thing, be sure and use some tape or something to cover your plastic pieces when prying them out. They are incredibly easy to scratch.
    Are you just installing the HU, or are you installing speakers/amp/sub as well? Also, are you going to deaden the doors?
    Good luck! Take some pics and let us know how it went.
  4. Feb 12, 2010 at 7:30 AM
    TREY4x4
    Trey
    Dacula, GA
    Personally I like the clean look of just the 7" display on the Z110BT. I don't like having buttons and the CD/DVD opening visible, although I do like the eco drive of the x920BT. All boils down to personal preference.
  5. Feb 12, 2010 at 7:34 AM
    TREY4x4
    Trey
    Dacula, GA
  6. Feb 12, 2010 at 9:07 AM
    dk6487
    David
    Novato, CA
    I didn't know new models were coming out. My H.U. was a little cheaper than the x920BT and the screen is 7" (the x92BT is only 6.1")
  7. Feb 12, 2010 at 9:11 AM
    dk6487
    David
    Novato, CA
    The only accessories I'm adding is the Ipod and back up camera w/ my now PopnLock. For now I'm just installing the H.U. Eventually I would like to deaden the cab, install amps and speakers but money is tight (as with most of us.) Thanks for the tips. Where did you end up mounting the BT mic?
  8. Feb 12, 2010 at 9:42 AM
    TREY4x4
    Trey
    Dacula, GA
    I ran the cable/mic through the passenger side of the dash, up through the passenger side pillar and mounted it right next to the rear view mirror. I just stuck the cable underneath the headliner. I was a little concerned at first about the location to mount it and running the cable, but it really was very easy. I'll try to take a pic later this evening...
  9. Feb 12, 2010 at 1:04 PM
    dk6487
    David
    Novato, CA
    Does anyone know if I'm better off splicing the grounds together (from stereo wiring harness to factory harness) or should I ground straight to the chasis behind the stereo? In past installs I've just connected the black grounds together and called it good.
  10. Feb 12, 2010 at 2:00 PM
    azTRD
    azTRD Well-Known Member
    You can check out this link on the upgraded Z110BT here:
    http://avic411.com/forum/viewtopic.php?f=56&t=30778
    It is likely that Z110BT owners will be able to upgrade their HU to the 'new' software that the x920BT has. Pioneer has done this in the past, so it is likely they will do it with the Z110BT. I'm sure it will have a cost associated with it, but if you were really wanting to go that route it would just be a software update without replacing the whole unit.
    It looks like the replacement for the Z110BT will be the Z120BT, but it also looks like it is just the Z110BT with the upgraded software installed.
  11. Feb 22, 2010 at 3:45 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    damn that new software is badass. I hope Ill be able to upgrade my z110bt
