Has anyone installed ARB compressor with AOB switch?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2chains, Dec 9, 2015.
  1. Dec 9, 2015 at 8:30 PM
    2chains
    2chains [OP] Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    The ARB CKMA12 compressor comes with a great harness and looking at numerous posts it seems like a straight forward install however I want to use the AOB switch instead of the ARB switch. This seems a little more complicated. Has anyone attempted this?
    I have previously hooked up a light bar with an AOB switch with fuse/relay with no issues.
    Using diagram 1 AOB indicates their switch must be installed with a fused relay. Is a second relay required as the ARB already has one? Also if a relay is required which of the ARB wires would go to 87 at the AOB relay? Any info would be appreciated.
  2. Dec 9, 2015 at 9:22 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    My ARB compressor and f/r lockers are wired through air on board switches. No need to use any additional relays, you are using a different switch only.
    You will have to spend some time with both wiring harness instructions and figure out how to put them together. Well if you're not running lockers it is pretty simple. You just need to look at the instructions for both and interpolate which wires connect to the others.
    DNATACO likes this.
  3. Dec 10, 2015 at 5:29 AM
    2chains
    Calgary, Alberta
    Those switches look great on your dash, just like a factory application! Thanks for confirmation on the relay, I wasn't 100% on that and also the 3A fuse requirement on the diagram. Looking at the diagrams the red/yellow AOB looks to run to the red on ARB harness. I'm going to power it through my Blue Sea fuse block and get this done!
  4. Dec 11, 2015 at 1:17 PM
    2chains
    Calgary, Alberta
    Brjw, Thanks again for your help. Really like your setup with the solar panels and the dual battery location is a great idea!
  5. May 3, 2018 at 6:08 PM
    grant.hamby
    grant.hamby New Member
    Grant
    2017 Tacoma TRD Pro
    Quick question about this: I’ve wired an AOB switch to my ARB comp and everything works just fine, but the graphic portion of the switch is constantly lit even when the switch is in the “off” position and even when the dash lights are off. The text portion of the switch illuminates with the rest of the dash lights like it should.
    So.. How do I get the graphic portion to only illuminate when the switch is in the “on” position?
  6. May 4, 2018 at 7:16 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    it sounds like you have constant power to the graphic you may have one of your wires on the wrong terminal
  7. May 4, 2018 at 7:28 AM
    grant.hamby
    Grant
    2017 Tacoma TRD Pro
    Yeah I bet you’re right. I’ll pull it out and look at it today. I might just have to test some different configurations.
  8. May 4, 2018 at 3:14 PM
    grant.hamby
    Grant
    2017 Tacoma TRD Pro
    Fixed it! Looks like I just had the red and the red/yellow mixed up.
  9. May 5, 2018 at 11:49 AM
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    Awesome glad you got it . Nothing is more frustrating than have wiring not working
