Has anyone made their own light bars?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JTacoma, Aug 25, 2011.
  1. Aug 25, 2011 at 8:28 PM
    JTacoma
    JTacoma [OP] Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    I want to add two Hella 700s or two KCs and I don't want to drill into the bumper. I think I can make my own light bar.
    I want to make something like the N-FAB or ellis light bars or just make two tabs or brackets big enough to hold a light and bolt it near the license plate on both sides where my aftermarket fogs are.
    Has anyone made their own light bar? Show me some pics so I can get an idea.
    Thanks for the help.
  2. Aug 25, 2011 at 8:42 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    It probably would be pretty simple to fab up a simple bar that bolts or welds up to your frame through the slots by the license plate. Some 2X2" steel would work well for the bar part.
  3. Aug 25, 2011 at 8:47 PM
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I believe Tw member snobord made some and sold them to other members. Idk if they would fit the very first generation of Tacomas but you could look to them for a little inspiration
  4. Aug 25, 2011 at 8:52 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I actually like the purple color on the 95-96. Nice truck!
    It wouldnt be too hard to bolt a bar onto the steel bumper behind the plastic.
  5. Aug 26, 2011 at 5:57 PM
    JTacoma
    Washington
    Nobody has any pics?
    Oh well, thanks for the input. I'll post a picture when I make a bar.
  6. Aug 26, 2011 at 6:01 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
  7. Aug 26, 2011 at 6:11 PM
    David K
    Here was the finished bar on my '05 Tacoma:
  8. Aug 26, 2011 at 6:20 PM
    David K
    After a trip into Baja, to Gonzaga Bay... BOTH Kragen HID lamps cracked! The black ABS plastic is no match for Baja's washboard graded roads!
    Josh repaired them both with fiberglass... but next Father's Day he gave me a pair of Hella 4000 METAL lamps (see post above).
    The most recent change as to make room for all 4 lamps... then I tried converting the Hellas to HID.
  9. Aug 26, 2011 at 9:23 PM
    TacoMX
    Jonathan
    Deltona, Florida
    nice work!^^
  10. Aug 26, 2011 at 11:52 PM
    DaveCanuck
    DaveCanuck Well-Known Member
    Dave
    Canada
    2011 SR5 V6
    Funny this thread should come up. I was already wondering about how to mount round lights on either side of the license plate.
  11. Aug 27, 2011 at 8:26 AM
    David K
  12. Aug 27, 2011 at 2:06 PM
    JTacoma
    Washington
    Thanks everyone for the help. I'll let you know how it turns out. I don't know if I want the brackets to go through the bumper or under.
  13. Aug 27, 2011 at 2:17 PM
    dmz1241
    dmz1241 Well-Known Member
    Dan
    SE, Connecticut
    01 Gold DC TRD
    Bilstein 5100's all around, Eibach coils, 2" shackles, Flowmaster 60 Series
    i have some pics in my build if you want to look there.
  14. Aug 27, 2011 at 3:17 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    i made what i call a light bar that goes behind my grill out of aluminum angle iron and it has worked flawlessly for me so far, so ou could try something along those lines if you can find a light to fit behind your grill, check out the last page of my build for pics.
  15. Aug 30, 2011 at 2:01 PM
    JTacoma
    Washington
    I got started making the light bar today after finding some left over metal in the shop. It is kind of like the one dmz1241 made. The brackets bolt into the existing holes where the fogs were. I still need to cut the brackets shorter so it is closer to the truck then weld them on. Then i'll weld caps on the ends to close it up and paint it. Here are some pics of what I have so far. It's simple but I think it will work.
  16. Sep 2, 2011 at 12:46 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    Dont have any pics on this computer..but look on my pics i think there a few you could get an idea from.
  17. Sep 2, 2011 at 12:51 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Plenty of people have pics but it's a matter of how applicable they are to what you're looking to do.
    Mine:
  18. Sep 2, 2011 at 1:28 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    ^^i think you need some roof lights too man
  19. Sep 2, 2011 at 1:31 PM
    mjp2
    NJ
    If/when I start running scheduled night races I'll have a bar across the top of the windshield in addition to what's on the front of the truck. :)
  20. Sep 2, 2011 at 1:36 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sick dude lol im planing on 4 up top and maybe 3 up front plus fogs...i think ill be good with that...not trying to fry anyones eyes out ;) lol
