Has anyone pulled an Airstream?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Petex46f3, Apr 14, 2020.
  1. Apr 14, 2020 at 4:43 PM
    Petex46f3
    Petex46f3 [OP] Member
    Bay Area
    2020 Tacoma TRD off-road DCLB - quicksand
    Hey all,
    My housing situation is about to change, possibly for the better. I am considering purchasing a 2020 Airstream Flying Cloud 23’ trailer.
    It’s specs are:
    Hitch Weight
    467 lbs
    Gross Weight
    6000 lbs
    Dry Weight
    4806 lb
    I believe my 2020 DCLB TRD-OR is rated for 6400 lbs.
    Has anyone here with a Taco pulled a 23 or 25’ Airstream?
    What was your personal experience?
    Thanks
  2. Apr 14, 2020 at 4:46 PM
    Daria
    Daria Can I pet your dog? Moderator
    Dodging tumbleweeds
  3. Apr 14, 2020 at 4:47 PM
    Stoked
    Stoked Not So Well-Known Member
    Jeff
    Celina, Tx
    2016 DCSB TRD OR
    Pull it once and leave it somewhere, or pull it all over the country?
    MadDaddy likes this.
  4. Apr 14, 2020 at 4:48 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    So that Gross Weight.... that's before you load the closets, and toilet, and bedding and fridge and ... right?
    I'm pretty sure the summary is going to be "you're going to hate life" combined with "have fun getting 6 MPG".
    I feel that you'd be better served by a diesel truck to tow a trailer that big, which means not a Tacoma.
    MadDaddy and Cypherian like this.
  5. Apr 14, 2020 at 4:49 PM
    Petex46f3
    Bay Area
    Mostly pull it once and leave it, but move it 1-2x/year, mostly west and southwest US. so both?
  6. Apr 14, 2020 at 4:50 PM
    Petex46f3
    Bay Area
    That’s the reply I was expecting, and you’re probably not wrong, but not what I was asking for specifically.
    Has anyone done this, and what was your experience?
  7. Apr 14, 2020 at 4:51 PM
    Stoked
    Jeff
    Celina, Tx
    2016 DCSB TRD OR
    If you are gonna pull it once or twice a year to move somewhere and park, you can manage. If you are gonna become full time RV'er and drag it all over the place, then get a bigger truck.
  8. Apr 14, 2020 at 4:53 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That's an easy trailer to pull with any 1/2 ton truck. Diesel not needed.
    Your Tacoma is going to suck pulling it.
    4000 RPMs and 6 mpg is going to get old fast.
    If only 25 miles to the local campgrounds, then no worries.
    98tacoma27, MQQSE and MadDaddy like this.
  9. Apr 14, 2020 at 4:55 PM
    Daria
    Dodging tumbleweeds
    I wouldn’t even enjoy towing that with my Tundra. Any modern half ton in Florida would do fine with a 23-25’ airstream. Elevation is a pain.
    Chew and MadDaddy like this.
  10. Apr 14, 2020 at 4:56 PM
    Clearwater Bill
    Billy
    Largo Florida
    While you may not get specific answer to an Airstream, the weight and bulk are what matter.
    As others are kind of suggesting, it's marginal. Totally dependent on where you tow, how often and how far. 'Where' includes terrain and weather too.
    Obviously you need every saftey advantage you can get, equalizer, brakes etc etc.
    But in the end you still probably won't enjoy it.
    Consider how a good cross-wind gust will likely permanently soil your upholstery.
    Petex46f3[OP] likes this.
  11. Apr 14, 2020 at 4:59 PM
    Daria
    Dodging tumbleweeds
    Recently purchased a 6900 GW travel trailer. At the time of purchase, we had a Tundra and Power Wagon. Both rated at roughly 10k. Towed the trailer 2500 miles with the Power Wagon and had to deal with filling the tank every 200 miles. As a result, we recently purchased a diesel. In several years, we may upgrade to a bigger trailer and it won’t be an issue, because diesel.
    MQQSE likes this.
  12. Apr 14, 2020 at 5:00 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Just tack $6k into the price tag and get the soon to be released OVTune turbos. Base kit will get you ~380hp compared to stock 278.
    But to your actual question... Airstreams should pull pretty well pound for pound when compared against other travel trailers. I’m personally planning for a ~4300lb Airstream in about 2 years.
    As others have said, it’ll want to rev high, and mpg may suck. I pulled a 3700lb and averaged about 9mpg. But it was through the hill country and I didn’t baby it.
    <edit> this was not an airstream however. Big square box camper.
    If you’re moving it 1-2 times a year, are willing to deal with stopping every 150-175 miles for gas, and are okay listening to 3500-4000 rpm, then it will get the job done.
    There’s not much margin left for cargo however. Taco runs out of payload quickly.
    Gen3TacomaOBX and Petex46f3[OP] like this.
  13. Apr 14, 2020 at 5:02 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    A good rule to follow with 2nd/3rd gen Tacoma's with Tow Package is to keep it under 4000 lbs dry.
    4800 lbs dry and 6000 lbs loaded is white knuckling it in the Tacoma. I've done it, hated every momented, and swore never again. Road manners, mpgs, high rpms, and borderline dangerous when merging or overtaking.
    4800 lbs dry, a 1/2 truck or full size would make easy work of it.
    BSFord and Petex46f3[OP] like this.
  14. Apr 14, 2020 at 5:47 PM
    TacoPlatter
    TacoPlatter Well-Known Member
    Michigan
    2017 Double Cab Off Road
    Best answer I can give is that my wife's Highlander tows our boat better than the Tacoma. Look elsewhere for a tow vehicle of any substantial capacity.
  15. Apr 14, 2020 at 6:12 PM
    Tacoma Mike
    Southern Maine
    Naaaaaaaa....
    Chew and Casper66 like this.
  16. Apr 14, 2020 at 6:24 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    The question stinks of "how much can I get away with?"
    In my opinion that trailer size and weight narrows the safety margin too thin. You'd probably get away with it, or you might kill yourself. Pray you don't take anyone with you if the latter. My 2¢...
    Chew, Casper66 and koditten like this.
  17. Apr 14, 2020 at 6:41 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I have pulled up to 6500 lb with my Tacoma. Truthfully, my truck didn't like much over about 4500 lb. I've pulled trailers all my life so I have a bit of experience. The last thing I pulled with my Tacoma before fixing it was a 6K trailer with two scissor lifts. It really did not like it. So, I fixed it by trading for a Tundra. Now 6K is no problem.
    Petex46f3[QUOTED][OP] likes this.
  18. Apr 14, 2020 at 6:42 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    /thread
  19. Apr 14, 2020 at 8:55 PM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Somebody on TW has a 23' they tow. I think they live in Colorado.
  20. Apr 15, 2020 at 5:17 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Correct!
    You're looking at pulling a nearly $100k trailer with the wrong truck. It's clear the funds are there, do it right, safety is not just yours.
