has anyone put an engine from a 2012+ Tacoma in a 2011- Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jboudreaux1965, Aug 7, 2017.
  1. Aug 9, 2017 at 8:19 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    What else would I need? I'm assuming ECU for sure, will ECU direct plug in?
  2. Aug 9, 2017 at 8:56 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah. The 4Runner uses the same gauge cluster and lots of parts are interchangeable and the the front frame is basically the same. You'll also need the 4Runner engine mounts (they work on the Taco) and the ignition circuit because of the immobilizer. Possibly the fuel pump, I think it's pressure regulated by the ECU.
    That's the big ticket items. Once you got that done you're 99% back on the road
