has anyone ran bilstein at 1.75 and eibach?
Discussion in 'Suspension' started by jerretxx, Apr 12, 2011.
  1. Apr 12, 2011 at 3:33 PM
    jerretxx
    jerretxx [OP] Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    has anyone ran bilstein at 1.75 and eibach springs?
  2. Apr 12, 2011 at 3:34 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    You will have nothing but problems, don't do it
  3. Apr 12, 2011 at 3:40 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    That's more or less what the Toytec CO's are!
    Search, you'll find at least a few people running that setup!
  4. Apr 12, 2011 at 3:43 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    NO! you will not see people running that setup .85 is the highest setting you can set the 5100's with the Eibachs.
  5. Apr 12, 2011 at 3:50 PM
    jerretxx
    Jerret
    North Carolina
    thats what i thought. can you explain why bc toytec didn't do a very good job explaining why, they just say don't.
  6. Apr 12, 2011 at 3:52 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    isnt that a good enough reason? the company that sells them says dont we say dont because they say dont.
  7. Apr 12, 2011 at 3:55 PM
    jerretxx
    Jerret
    North Carolina
    they just said stiff ride and possible damage to axle. but whats the difference in that which is equal to 3.25" and the toytec coilover which you can extend to 3.5? i trust you guys and set them to .85, i just wanna know the difference
  8. Apr 12, 2011 at 3:56 PM
    johnw
    john
    orlando florida
    to be honest i dont know why it just isnt good. somebody will chime in that knows why maybe chris4x4 will know
  9. Apr 12, 2011 at 3:57 PM
    jerretxx
    Jerret
    North Carolina
    alright man, thanks for the info
  10. Apr 12, 2011 at 3:58 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You cannot run anything over 3" of lift on a tacoma (without a drop bracket or SAS) because the shocks will have basically no down-travel left, and at full droop your ball joints will be binding.
    EDIT: and if it's not obvious, what I was getting at is that 1.75" +1.6" = 3.35" of lift.
  11. Apr 12, 2011 at 3:59 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Aren't the Eibach coils already 1.6" longer than the OEM coils ?
  12. Apr 12, 2011 at 3:59 PM
    jerretxx
    Jerret
    North Carolina
    yes, thats what toytec website says
  13. Apr 12, 2011 at 4:00 PM
    KPT
    09 Prerunner
    They provide 1.6" of lift, correct. I'm not sure if it's all because of length, or if some of it is due to the springs being stiffer.
  14. Apr 12, 2011 at 4:02 PM
    jerretxx
    Jerret
    North Carolina
    i compared it to my stock spring when i installed, it might be about .5" longer, but its way stiffer. on the compressor we turned maybe 3 turns to compress stock spring with 113k miles, and the eibach took about 6 or 7 turns, it was a big difference.
  15. Apr 12, 2011 at 4:05 PM
    OZ-T
    Peter North
    British Columbia
    So they have a stiffer spring rate .
    If you preload them further with the billys they will ride like a rock .
  16. Apr 12, 2011 at 4:07 PM
    jerretxx
    Jerret
    North Carolina
    thats the only reason i can see, which with stiffer coils, you would have stiffer ride and it would be harder on everything else such as ball joints, axles, etc.
  17. Apr 12, 2011 at 4:23 PM
    theduck911
    Max
    Locked and Geared!
    Oh didn't know that, I thought it was similar to what I was running or the OME setup, my bad
  18. Apr 12, 2011 at 4:28 PM
    jerretxx
    Jerret
    North Carolina
    right i understand this, but how is it that some are running 3.5" with coil overs? Relentless is running 3.25" with out SAS or DB, are they just simply ignoring all this, or do they have something i don't see?
  19. Apr 12, 2011 at 4:29 PM
    OZ-T
    Peter North
    British Columbia
    They are probably OK with replacing the CV's periodically .
  20. Apr 12, 2011 at 4:34 PM
    jerretxx
    Jerret
    North Carolina
    thats what i figured. i just want mine to sit more level, its still front heavy.
