Has anyone replaced the grille on a 2022 TRD Sport?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by armygre3n_tacoma, Apr 12, 2022.
  1. Apr 12, 2022 at 7:53 PM
    armygre3n_tacoma
    armygre3n_tacoma [OP] Member
    Hey all - first time poster! I love this site...
    I've watched a ton of videos and read several threads on this topic. However, I can't seem to get the grille off of the 22 TRD Sport.
    I've removed the two 10mm bolts, four of the clips at the far bottom and two by the lights (one by each side) for a total of 6 clips and the 2 bolts. It seems like something else is holding it in place still.... What am I missing?
    Side q: do ya'll get the TSS Sensor recalibrated after changing?
  2. Apr 12, 2022 at 8:46 PM
    oldtoyman
    oldtoyman Small bore freak
    Kevin
    North of Seattle
    1994 Harley heritage,2019 Honda Monkey,2023 klx300 , 2013 prerunner TRD off-road
    Two bolts two clips on each side top and pull. It’s that easy. I can pull mine in about 3 min.
    shakerhood likes this.
  3. Apr 12, 2022 at 8:48 PM
    armygre3n_tacoma
    Two clips in total? As in one by each light?
    How hard do I have to pull? I felt like I have it a decent pull but I'm afraid I'll snap some of the cheap plastic...
  4. Apr 12, 2022 at 8:58 PM
    oldtoyman
    Kevin
    North of Seattle
    Yes two clips. I know it feels wrong to just pull but that’s it. Grab it by the top and pull.
  5. Apr 12, 2022 at 8:58 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  6. Apr 12, 2022 at 9:03 PM
    oldtoyman
    Kevin
    North of Seattle
    Disconnect the wire connector first. Also lay the grill on a soft blanket or towel so you don’t scratch it up. That would be my only advice that this guy in the video didn’t do. Otherwise it’s that easy.
    Spacecoast likes this.
  7. Apr 13, 2022 at 11:34 AM
    armygre3n_tacoma
    I've seen this (and a lot of others). All of the videos make it seem like it can be removed with minimal force. Just some pressure and pull it out.
    I guess my question is that I'm wondering if they added new clips on the 22. It definitely seems like something is holding it in place but maybe It's just because it's new.
  8. Apr 13, 2022 at 11:38 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    No, they are using the same clips as before. Also, you do not need to re-calibrate the TSS sensor. Putting a washer or two underneath it is sufficient.
  9. Apr 13, 2022 at 7:44 PM
    armygre3n_tacoma
    Thanks! Got it off, finally. Just found the right angle and it clicked.
    Regarding the TSS sensor, I did one washer and I'm getting the sign on my dash that it's malfunctioning. I guess I'll have to try another. Would it matter if my truck is lifted with 33s (changing the height from the ground?
  10. Apr 13, 2022 at 7:47 PM
    Borracho Loco
    DFW, Texas
    Nope, the lift doesn't really affect it; it just changes the view point. Disconnect the sensor cable, then re-connect it. Make sure it clicks securely.
  11. Apr 13, 2022 at 7:48 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    The plastic isn’t really cheap considering what your paying.
  12. Apr 13, 2022 at 8:08 PM
    armygre3n_tacoma
    I'm pretty sure it's in all the way but worth a try! The light isn't always on btw. It's usually off when I start driving and comes on after a couple mins. I've read that they calibrate themselves over time though...
  13. Apr 13, 2022 at 8:09 PM
    armygre3n_tacoma
    Fair point. Just didn't seem overly sturdy but I was wrong!
    Benny blanco[QUOTED] likes this.
  14. Apr 13, 2022 at 9:24 PM
    RyanDCLB
    4/19 DCLBOR
    You might want to unplug the battery for 15 minutes or more, and then try to see if the front sensor resets itself. It may not be necessary to add a washer, as I didn't add a washer to my truck with a 3-inch lift. I have no issues with the TSS. Of course, please refer to Toyota recommendations.
    armygre3n_tacoma[OP] likes this.
  15. Apr 14, 2022 at 6:06 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Yeah mine would sometimes have issues for a little then the issues went away- I’d drive it for a couple weeks before getting too crazy. Holding the cruise button down will activate normal cruise in the interim
  16. Apr 14, 2022 at 4:51 PM
    armygre3n_tacoma
    Thanks. Today I drove around for 20 mins or so with no issues whatsoever. And I did nothing to it. Maybe it just took some time to reset?
  17. Apr 14, 2022 at 9:34 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    Sounds correct. As long as you dont have a monster lift and reinstalled the sensor perfectly you shouldn’t have any issues . You really have to mess things up bad to need it recalibrated by the dealer. Ive done 2 swaps(‘21+ ‘22 Sports with cameras ) and never had any issues.
