Has anyone replaced the TENSIONER on the V belt..???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Tacoma, Oct 6, 2011.
  1. Oct 6, 2011 at 7:12 PM
    Mr.Tacoma
    Mr.Tacoma [OP] Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    Folks..Lookin for tips on how to..change tensioner..without much hassle. thnks:)
    Update..found another TW mmbr(johnW) done the work with some pics here.
  2. Oct 6, 2011 at 7:50 PM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    not that easy on the 05+ tacoma's
    yeah you can do that then you'll have to un bolt the alternator and a/c compressor to gain access to the mounting bracket bolts, i haven't done it but it looks like a nightmare
  3. Oct 9, 2011 at 5:06 AM
    Mr.Tacoma
    toronto
    DoubleCab4x4
    I was under/over the truck..releasing tension and taking off belt is easy part..removed alt (easy part) A/C compressor sits on 4 bolts..removed 2 on top but 2 are at bottom and is almost impossible to access as the frame is right under it and i could not use impact or even hand wrench..tried and gave up..put it all back together to take it to a mechanic. I was quoted C$120-130 for installation..its not worth fighting over it. :mad:
