Has anyone retrofitted disc brakes in the rear?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by N2DesignsInc, Feb 24, 2018.
  1. Feb 26, 2018 at 8:17 AM
    #81
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I will say, as someone who does a lot of gravel driving and has done so with several late model trucks, that rear discs are a pain in the ass. Yes, they are better at heat dissipation than a drum. Yes, it's usually easier to change a disc brake pad than a drum. However, especially with aftermarket setups, if there is an sliver of a crack between the dust plate and the rear disc or caliper, you will get rocks pinched between the disc and the rotor. If you drive with even a pebble wedged in the caliper for any amount of time, the rotor is ruined and you have to get a new one usually with the way the newer trucks are setup. Sometimes you hear it, sometimes you don't.
  2. Feb 26, 2018 at 8:18 AM
    #82
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    In the 90's Dodge actually had lots of trucks that were only ABS in the rear and the rears were drums. From my understanding it was a technical limitation that they tried to spin into a safety feature. Once they had four wheel ABS the safety feature argument dropped off the face of the earth.
  3. Feb 26, 2018 at 8:31 AM
    #83
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I am fine with the brakes on my truck, but if you are driving thru and hauling that much gravel are you also getting it stuck in the front calipers? Seems like the front would be more open and exposed to the pebbles since the wheels are turning left and right.
  4. Feb 26, 2018 at 9:27 AM
    #84
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pebbles only get caught in the disks of rear swaps. ;)
  5. Feb 26, 2018 at 9:41 AM
    #85
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Why are we still hashing on this silly subject? :deadhorse:
    If you just have to have disc brakes on the rear of your truck just because, then go do the conversion. :sawzall:
    If you feel you are being cheated out of rear discs because all the cool trucks nowadays have them, go buy one of those more awesomer trucks then. :jerkoff:
    However, if you really can't say for sure that your truck has an issue with the drums on the back of your new truck, then you probably don't have a problem with the drums.
    If you really don't give a rats ass about what kind of brakes all the new trucks have on the back theirs, and you are perfectly fine with the full functioning rear drums it came with, lemme get a "Hell yeah!" from ya.
    :yay::dancingbacon::broccoli::bananadance::kona::jellydance::woot:
    specter208 likes this.
  6. Feb 26, 2018 at 9:55 AM
    #86
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I drive tens of thousands of miles of gravel a year. The rears are way worse than the front because of how gravel behaves. It's almost like water, as your tires go through some is picked up in the tread and thrown randomly and some is spilled out sideways almost like wake. Given how gravel is oddly shaped and bounces it has no problem finding the little spaces it can get into on the rear discs if you drive enough miles. It all comes from the actions of the pebbles and rocks coming off the front tires one way or another.
  7. Jan 20, 2019 at 6:00 AM
    #87
    owenfred
    owenfred Member
    If you drive through water every day like I do, the shoes will sieze to the drum. This happens on the brake shoes and especially the parking brake.
    The Tacoma manual even says not to set the parking brake in certain cold/wet conditions.
    I might do the swap just to eliminate this issue.... In some cases people do have good reasons for this conversion.
    If your truck is a pavement pounder there's no reason to swap unless you add big weight to your truck.
  8. Jan 20, 2019 at 6:20 AM
    #88
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    Agreed. I had this truck for 6 months and the E brake has locked up on me 3-4 times already (every time happened when the temperature dropped below freezing). I suspect that there was mud and/or water in the drum brakes as I go mudding every so often. One time it froze without having set the E brake. Fried my clutch every time trying to get it to release. Not sure why they have such old technology in a 2018 truck. Disc brakes are so much simpler and more effective IMO
  9. Jan 20, 2019 at 6:35 AM
    #89
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Hey, my brakes were fine until I added more weight and bigger tires. Youre forgetting there are times that you need to upgrade certain components to match others. It was a little dangerous at first with the stock brakes, but I upgraded all 4 corners and the MC to get proper fluid movement to the calipers, and basically created a balanced system once again by using 6 pistons up front and singles in the rear. Its pretty close to factory bias, with the rears locking up first so I can properly move the rear end around entering a corner but pedal feel is more than adequate to avoid dangerous 4-wheel lock situations.
    Torspd and su.b.rat like this.
  10. Jan 21, 2019 at 3:52 PM
    #90
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    Sooo..its official. I have a problem with the drum brakes (at least the E brake system). Shouldn't be locking up on cold freezing days 3 times in last month. I'm inclined to open up the drum brake and inspect it because I don't have time to bring it to the dealer. Appreciate any feedback or if any other members have experienced this as well.
  11. Jan 21, 2019 at 4:06 PM
    #91
    LeeVanChief
    LeeVanChief Well-Known Member
    2018 OR 6Speeeed Taco
    The brakes in the Tacoma are going to kill me one day. They are not good at all. Upgrade your fronts
    Jrgymie likes this.
  12. Jan 21, 2019 at 4:26 PM
    #92
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I believe the main question of the topic was not drum vs disc but rather the topic of the electric hydrobooster of the off road. The sport can swap in the sequoia master and call it a day. The off road is not easily swappable. Like everything else we get the itch upgrade or attempt to make an awesome truck better.
  13. Jan 21, 2019 at 4:29 PM
    #93
    cipherbreaker
    cipherbreaker Well-Known Member
    If drum brakes are so great, why haven’t any of these fanboys retrofitted them to the front? Why doesn’t Toyota put drum brakes on their full size truck? What about on any other vehicle they offer?
    Don’t @ me.
    Torspd likes this.
  14. Jan 21, 2019 at 5:00 PM
    #94
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    ..just to confirm, the master cylinder in the TRD Sport can be retrofitted with the OEM master cylinder in the larger Sequoia? If (when) I do upgrade to 4 wheel disc brakes I would consider upgrading the MC as well. I had a 08' BMW 335 which I upgraded the brakes to a later model BBK and upgraded the MC as well to the M3 version. Worked flawlessly and the car's stopping ability significantly improved.
    This truck needs beefer brakes and Toyota should at least offer a better brake package IMO. I also understand that if I lift the truck and stick on 33" tires plus armor, I shouldn't expect a stock brake system to perform outside stock specs.
    Torspd likes this.
  15. Jan 21, 2019 at 10:00 PM
    #95
    nudavinci64
    Robert
    Exactly. He Sequoia master is what SOS performance seeks for doing this swap. I was going to do that but did not take into account the difference in the off road.
  16. Jan 22, 2019 at 3:59 AM
    #96
    stevotivo12
    Stephen
    Because brakes are one thing that if theyre broken its too late and youre dead was my thinking
    ResidentCarbon and Torspd like this.
  17. Jan 22, 2019 at 6:08 AM
    #97
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You are all wrong. Both types of brakes are completely worthless, which is why I did a brake delete mod and now I only use a drag chute for stopping.
    For panic stops I fire the retrograde rockets, but I'm only allowed one panic per week. (I'm already maxed out on my purchase quantities of ammonium perchlorate before getting placed on some sort of watchlist.):spy:
