has anyone seen/used this oil?
Discussion in 'Technical Chat' started by dustinclm, Apr 18, 2011.
  1. Apr 18, 2011 at 10:18 AM
    dustinclm
    dustinclm [OP] Well-Known Member
    Thibodaux, La
    2012 Super White DC 4x4 V6
    Bilstein 5100 set at .85" WeatherTech Floor Mats
    it says "suitable for use in honda and toyota"
  2. Apr 18, 2011 at 10:21 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Seen, yes. Used, no. I just use what the book recommends. 5w30. The newer Honda and Toyota cara calls for that stuff.
  3. Apr 18, 2011 at 10:22 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Suitable??? I think I will use what is recommended. You want a 30 wieght anywho.
  4. Apr 18, 2011 at 10:23 AM
    dustinclm
    Thibodaux, La
    i only use 5w30 also but i noticed this last night and was curious
  5. Apr 18, 2011 at 10:25 AM
    dustinclm
    Thibodaux, La
  6. Apr 18, 2011 at 10:30 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I'm running the 0-30 in mine right now but I live in California with mile temps. I haven't seen a deference in Mpg's or start up's from using the 5-30
  7. Apr 18, 2011 at 10:39 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    0-30 Amsoil year round on 2nd gen
  8. Apr 18, 2011 at 10:39 AM
    crf69
    Ohio
    ummm yeah
    oil from Mobil or Amsoil is ALWAYS suitable
  9. Apr 18, 2011 at 10:41 AM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    I used that this past winter. Couldn't really notice any sort of difference. I did, however, have that yellowish buildup underneath the cap. I've switched to Royal Purple and haven't looked back. Just checked my cap the other day, and no buildup.
  10. Apr 18, 2011 at 10:47 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    Well is states 2% increase in MPG. Say you average 20mpg, with a 2% increase you will be getting 20.4mpg. You would be better off dropping your speed by 5-10mph. I like Penzoil Platinum, 17$ a jug so its chaeper too.
  11. Apr 18, 2011 at 10:47 AM
    JLee
    Jerry
    Grass valley CA
    The yellowsih buildup is most likely from short trips. it's moisture from the humidity in the air it will go away after a long drive.
  12. Apr 18, 2011 at 10:52 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    Sure is. Longer driving gets rid of the moisture. Once a week or so you should go for a "long" drive to burn the moisture off. Or let it run a little more before you leave and arrive.
  13. Apr 18, 2011 at 11:01 AM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    I wish I could find Mobil One 0W-20. By that I mean, I wish I could find it on base. I plan to use it after my free oil changes are used up. The 2010 owners manual says use 5W-20 or 0W-20 in the 4 cylinder. The lower the first number, in a multi-grade oil, the better the cold start protection.
  14. Apr 18, 2011 at 11:37 AM
    rex99
    TArdCOMAWORLD
    Proton Cruiser
    After I switched to Royal Purple, I had no buildup without changing driving styles.
    I don't know that I would use that light of an oil in New Mexico. Its pretty thin to start with, by the time you add hot, desert heat to the mix, your asking a lot of that oil. Good chance it will wear too thin and cause damage.
  15. Apr 26, 2011 at 4:22 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    My 2008 2.7 manual has 0/20 as the preffered oil ,good for economy . Now having said that.........
    So whats the "advanced fuel economy"? Is it, that it is synthetic? ...or that its 0-20? Or that they made it with a green label? If so then there is NOTHING new. What next ...eco -smart rounder steering wheels?
    Also, the manual tells you whats suitable, it is suitable if it had no other label than the oil grade and viscosity, i think they are just telling you what they want us to hear...... need to hear, to be more likely to buy it.
    Thats marketing ... make you believe. Dont get me wrong , mobil makes quality stuff,but why start doing the sales tag lines..... what next....."BUT WAIT THERES MORE!!!!"......"Whats in your engine"(err wallet?)
    Marketing... YOUR money is THEIR money......they are the capitalists , you are the cash farm, you will be harvested. Ever try any line to get into a girls pants? What do you thing they do to get into your wallet?
    think I'll buy a different oil just to peeve them for now , I like to punish cheap shot marketing by not buying it.anyway,I'm not seeing a provable gain in economy with synthetics over good dino oil at 0/20. Just my $.02
  16. Apr 27, 2011 at 6:49 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    last trip to wally world, i believe the regular synthetic and this stuff was the same price...same as the high mileage synthetic.
  17. Apr 27, 2011 at 4:11 PM
    Tacoyota
    08 4wd
    Seems like here in potland...er Portland , they jack the synthetic prices up. I like the stuff, but for the price, I'm liking a regular oil, quality brand of 0/20.But like you said, it was the same price as other synthetics. Sorta shows the "Advanced fuel economy" line is just like saying better than oil 8 years ago, but nothing new in the last 1-2. I take that back if they actually came out with a new api grade since 2009.Pretty packaging though.:D
    Bah , late threadjack, republicrats and dempublicans still blabbering about the birth certificate. If we as a nation seem to vote people in on popularity,why dont they just go for the sexiest actress.
