Has anyone taken apart an HID bulb?
Discussion in 'Lighting' started by memario1214, Jan 6, 2011.
  1. Jan 6, 2011 at 10:36 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Well I have 4 HID lights up front and my issue is that the leads from the ballasts to the bulbs just aren't long enough. So I spliced them (dumb-ish) and extended the lines so that I didn't have the plugs/ballasts hanging out of my truck. I am now occasionally having firing inconsistencies because as I attempt to hide the wires, I am getting a pinch right at the solder and the ballast senses that and stops sending power. Does anyone know how the wire connects to the bulb as well as where someone may be able to obtain some longer leads that go to the bulb.
  2. Jan 6, 2011 at 10:51 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    what wire did you use to extend them?
  3. Jan 6, 2011 at 10:56 AM
    Chachie
    Justin
    Nor Cal
    This...It is ok and it works if you use high voltage wire and connectors. But otherwise you are asking for trouble. You can actually buy extensions for the bulbs online.
  4. Jan 6, 2011 at 10:57 AM
    memario1214
    Colton
    Missoula, MT
    The same size wire used on them in the first place.
    Yeah, I know that now... But I was young and dumb. Everything is spliced and sealed right but a) it doesn't look great and b) when I try to hide them, one of the bends is on a splice point and it pinches and yes... essentially shorts out.
    I understand what I should and should not have been doing haha. I just want to know if I can go back and fix er!
  5. Jan 6, 2011 at 10:58 AM
    Chachie
    Justin
    Nor Cal
    just buy new bulbs. They are $15/pr from ddm with a lifetime warranty.
  6. Jan 6, 2011 at 11:00 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Yup, These are actually high voltage. HIDs require 23,000 volts to fire. This kind of voltage requires specially insulated wiring. The best thing is to buy commercially made extensions.
    http://www.carhidkits.com/wiring-adapters-752/xenon-hid-bulb-extensions-pair-381.html
  7. Jan 6, 2011 at 11:02 AM
    Chachie
    Justin
    Nor Cal
  8. Jan 6, 2011 at 11:02 AM
    PreRunnerSeth
    Apex, NC
    Only good if he spliced it on the bulb wiring and not the ballast wiring.
  9. Jan 6, 2011 at 11:03 AM
    PreRunnerSeth
    Apex, NC
    Sure
  10. Jan 6, 2011 at 11:04 AM
    memario1214
    Colton
    Missoula, MT
    Haha I don't need new bulbs though. I will still have the exact same problem... I still need a bulb with longer leads in order to properly plug in as well as conceal the wires you know?
  11. Jan 6, 2011 at 11:05 AM
    Chachie
    Justin
    Nor Cal
    good point. new ballasts are what like 30?
  12. Jan 6, 2011 at 11:06 AM
    memario1214
    Colton
    Missoula, MT
    I did in fact splice the bulb wiring. That way I was able to move the connections further into the truck
  13. Jan 6, 2011 at 11:09 AM
    PreRunnerSeth
    Apex, NC
    So buy new bulbs and the proper extensions.
