Has anyone used these crossbars for the prinsu roof rack?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jardoo, May 4, 2025.
  1. May 4, 2025 at 8:00 AM
    jardoo
    jardoo [OP] Well-Known Member
    Beirut, Lebanon
    2016 DOUBLE CAB MGM 4X4 TRD OFF ROAD SHORT BED
  2. May 4, 2025 at 8:42 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Its just aluminum extrusion. As long as its the size that matches the Prinsu, those'll be just fine.
    jardoo[OP] and OnHartung'sRoad like this.
  3. May 4, 2025 at 8:44 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    They are exactly the same as the Prinsu ones. TNutz is a very good company by the way, with great service!
    jardoo[OP] and fatfurious2 like this.
  4. May 4, 2025 at 12:54 PM
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    I just ordered 2 of these a couple weeks ago to replace ones that the stupid cheap screws broke off in. Much cheaper but they lack the little slot to drop in anchors or bolts without unscrewing the crossbar.
    jardoo[OP] likes this.
  5. May 4, 2025 at 2:06 PM
    OnHartung'sRoad
    That slot you mention on the bars are probably only on the newer Prinsu racks- the original rack sold by the creator didn’t have that. Does sound nice if you change your setup a lot, but not a big deal.
    The big issue you mention is broken mounting bolts, how did that happen? Are they using crappy hardware now or did you accidentally over tighten them? I have a heavy RTT on mine and the bolts have never snapped. You can remove the broken studs with an easy out and if that fails with a drill and tap if you want to recover those bars.
  6. May 5, 2025 at 10:40 AM
    44-16 Taco
    KMS
    I assume its galvanic corrosion and cheap hardware combined for spectacular results. Mine broke off when trying to back them out to move the bars. Probably should have put some anti seize on the bolts originally, but I didn't.
  7. May 5, 2025 at 1:04 PM
    OnHartung'sRoad
    Wow that’s crazy. I’ve had mine on since 2017 and the bolts are just fine. But then again, I do live in a pretty arid place with no snow.
    44-16 Taco[QUOTED] likes this.
