Has anyone with the howling rear end gone into the rear?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodrow F Call, Apr 5, 2017.
  1. Apr 7, 2017 at 8:13 AM
    #81
    Prof_KeenBean
    Prof_KeenBean Well-Known Member
    Charlotte, NC
    '17 OR 4x4 DCSB MGM
    Not sure if this has been stated but if it were bad gears or bearing wouldn't it howl all the time and not when feathering the throttle at a specific speed? Again, I am not familiar in the area but just curious if that would make a deference. Mine does not howl, 2,500 miles.
    Storman likes this.
  2. Apr 7, 2017 at 8:30 AM
    #82
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Sounds about right.
    You could also add that pretty much all new 3rd members that were installed as a corrective measure began to howl as well (read: new diffs in stock have not been corrected yet).
    Some were done twice and ended up with the same problem!
    Frank
    shakerhood and Inferno500 like this.
  3. Apr 7, 2017 at 8:33 AM
    #83
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    No. The needle bearing failure for instance only shows symptoms at certain speeds. But it's been verified time and time again what the problem is and that there is in fact a design flaw there and the solution is to replace with a bushing. So symptoms of a problem can in fact be speed specific.
    shakerhood, Storman and MOC221_ like this.
  4. Apr 7, 2017 at 9:09 AM
    #84
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    One would like to think they will get a handle on it soon.
  5. Apr 7, 2017 at 9:12 AM
    #85
    WOTaco
    WOTaco Well-Known Member
    NY near the old capital
    2016 MGM DCSB TRD OR MT
    Yea, it would be nice if it happened before the powertrain warranty is up!
  6. Apr 7, 2017 at 9:15 AM
    #86
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I'm banking on the fact that if they decide to put out a fix a few years down the road--as long as you have a strong history of documentation about it, then you can still get somewhere with them
  7. Apr 7, 2017 at 9:17 AM
    #87
    Storman
    Storman Fukitol abuser
    South Western PA
    2017 SR AC 4x4 AT AC UP ->LONG BED<-
    Whole bunch of shit! $$$
    BlakeM and busticator like this.
  8. Apr 7, 2017 at 9:57 AM
    #88
    MOC221_
    Frank
    Agreed.
    As someone else eluded to earlier, the rectification of this issue may well be tied up in red tape, up to and including legal issues, with a sub-contractor (ie the asshats who manufacture/assemble the diffs). And you can bet the bean counters have had more than a few looks at how much a fix would cost them. My guess is that if Toyota does fix this, the "improved" diffs will start rolling down the pike in new trucks without so much as a whisper. I expect there will be a TSB eventually, and someone on here will get a new third member that's "good". Then we'll get to see the paperwork complete with codes n such.
    Yeah, it's a long shot.
    Edit: And don't forget, there's got to be 10's of thousands of these things in production/shipped/in warehouses etc. You think those ones are going to be quarantined as non-serviceable and sent back to the supplier? No way. In the new trucks you go, production isn't going to stop.
    In the mean time, :burnrubber:
    Frank
    shakerhood[QUOTED] likes this.
  9. Apr 7, 2017 at 10:37 AM
    #89
    shakerhood
    Southern Ohio
    No doubt about it, whatever Vendor is making them surely has a stockpile that has to be used up before a fixed version is released.
  10. Apr 12, 2017 at 9:59 AM
    #90
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Add me to the list of those with howling rear ends. At 20k miles my 2016 DCSB OR MT howls like a bitch.
  11. Apr 12, 2017 at 10:22 AM
    #91
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Does it do it when you put it in neutral, I notice when mine is in neutral you almost can't hear it. I'm think most of my noise is coming from the Manual Trans.
  12. Apr 12, 2017 at 10:30 AM
    #92
    shakerhood
    Southern Ohio
    There was a new TSB for the Manual Trans for vibration noise or something like that, 1 guy on here had it done and it did not help with the howling.
    Diablo169[QUOTED] likes this.
  13. Apr 12, 2017 at 12:36 PM
    #93
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I don't know if Smitty posted it in here, but in the main thread he said he put a mild lift on the truck (possibly correcting the driveline angles) and the howl is gone.
    @smitty99
  14. Apr 12, 2017 at 12:58 PM
    #94
    TejasTaco
    TejasTaco Grab a taco
    The howl does not happen on Sport or Limited diffs?
  15. Apr 12, 2017 at 1:01 PM
    #95
    smitty99
    Scottsdale
  16. Apr 24, 2017 at 1:09 PM
    #96
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    It's backlash noise.
  17. Apr 24, 2017 at 1:15 PM
    #97
    smitty99
    Scottsdale
    :popcorn:
    shakerhood likes this.
  18. Apr 24, 2017 at 1:17 PM
    #98
    ToyoMann
    I recorded the noise and measured the frequency. I then calculated the ring and pinion tooth meshes. The recorded and calculated frequencies were within 5 Hz of each other.
  19. Apr 24, 2017 at 1:23 PM
    #99
    smitty99
    Scottsdale
    ToyoMann likes this.
  20. Apr 24, 2017 at 1:25 PM
    #100
    ToyoMann
    Not enough backlash can do the same.
    smitty99[QUOTED] likes this.
