Has anyone's e brake locked
Discussion in '2nd Gen. Builds (2005-2015)' started by Chasin Tail Toyo, Dec 30, 2013.
  1. Dec 30, 2013 at 8:34 AM
    Chasin Tail Toyo
    Chasin Tail Toyo [OP] Active Member
    USA
    2012 tacoma 4x4 TRD Off-road
    3" revtek suspension 265/75/16 Dakota m/t's Front mount Badland winch/ reciever 12" subwoofer 1100 watt amp RR diff lockers
    Has anyone's e brake on the automatics stayed stuck after you release the e brake, I released it and the front wheels stayed locked and the truck didn't wanna move
  2. Dec 30, 2013 at 8:35 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Yea but it's the rear wheels that the ebrake works on not the front...
  3. Dec 30, 2013 at 8:36 AM
    Large
    Large Red
    Mine did for the first time this past weekend. I locked / unlocked it a few times but nothign fixed it, I finally left it unlocked and put my truck in 4L with the locker engaged and it broke free.
  4. Dec 30, 2013 at 12:58 PM
    Chasin Tail Toyo
    USA
    My back tires spun front were locked, it unlocks if you turn off ignition and restart it again,
  5. Dec 30, 2013 at 1:03 PM
    Large
    Large Red
    If your front tires were locked, that's not your e-brake like jerez said.
  6. Dec 30, 2013 at 1:05 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, e-brake has nothing to do with the front. The e-brake operates the rear drums by means of a cable. I just had mine freeze up on me this past week (driver's side rear froze so the passenger side spun since it's an open diff). If your front is locking up, you have other issues.
  7. Dec 30, 2013 at 1:07 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    sounds like something is going on with the traction control...if it unlocks when you cycle the key
  8. Dec 30, 2013 at 1:21 PM
    Chasin Tail Toyo
    USA
    That's the same thing tha happened to mine this morning
  9. Dec 30, 2013 at 4:12 PM
    Geem750
    Geem750 Well-Known Member
    Brandon
    Okanagan, BC
    07 DCLB
    Grillcraft grill, ultimate toytek 3" lift, shorty antenna, blacked out badges, rear diff breather, Kenwood 6990 HU, wet okoles, weather techs, extra D-rings, Cruisin offroad bolt on sliders, Treklights 18" LED bar
    why is this in 2nd gen builds o_O
  10. Dec 30, 2013 at 4:19 PM
    Tac000
    Tac000 Active Member
    Paul
    Charlotte, NC
    11' Tacoma 4x4 6speed
    Mostly plasti-dip
    My rear wheels have locked after putting the boat in the water and letting the truck sit. I had to put it in 4Lo to break 'em loose... Guess I didn't wash it down enough.
