Has brake service gone up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MrGooch, Oct 8, 2024.
  1. Oct 8, 2024 at 12:08 PM
    MrGooch
    MrGooch [OP] Well-Known Member
    2021 Black TRD Pro
    Picking the 21 up at my mechanic. Gave him the oem pads and rotors, having them replace them, adjust the rear drums and flush the fluid... My bill is like $600. That seems expensive.
  2. Oct 8, 2024 at 12:09 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Sounds like "customer provided parts" tax to me.
  3. Oct 8, 2024 at 12:13 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're new here. There is a zero tolerance policy. I'd edit that?
  4. Oct 8, 2024 at 12:14 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
  5. Oct 8, 2024 at 12:23 PM
    MrGooch
    2021 Black TRD Pro
    I called a shop right next door to where my truck is now. They quoted me 160 for rear drum service, 160 for labor on the front rotors/pad install and 250 on a flush and fill.
  6. Oct 8, 2024 at 12:29 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    FishaRnekEd and Willy Lump Lump like this.
  7. Oct 8, 2024 at 12:34 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Everything has gone up.
    Shops make money on parts too, if you provide your own, most (if not all) will add that markup to the service charges.
    Taco Egghead likes this.
  8. Oct 8, 2024 at 12:40 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    How many miles on that '21..? Hard miles...?
    I would have got a few quotes for sure, or at least ballpark figures.
    MR E30 likes this.
  9. Oct 8, 2024 at 12:43 PM
    MrGooch
    2021 Black TRD Pro
    I have 42k on it now. did all the trans, diff fluids already too at 35k so just making sure it runs me good up until toyota gives us a new gen with a v6... in that case I may have it forever.
    Stevie17 likes this.
  10. Oct 8, 2024 at 12:51 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    do you drive hard? I feel most people get 50-60k out of their front pads and usually rotors last 2 brake pad changes.
    In my neck of the woods labor rate is 120-150hr. Id expect 400 min so 600 sounds about right for what they did.
    brake changes is probably the one thing I will always do myself because of the cost
    Taco Egghead and Stevie17 like this.
  11. Oct 8, 2024 at 12:54 PM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    my mechanic quoted me like $450 installed for my front brakes with him providing parts. and I think it would've been like $75 for the flush. If I handed him the parts he typically charges a little bit more on labor but it might be around $250 for installation with provided parts
  12. Oct 8, 2024 at 1:00 PM
    MrGooch
    2021 Black TRD Pro
    ok, so 600 is about fair I'm guessing. I'm busy and didn't have time to do it myself and with all the time watching yt vids doing all that is not worth a couple hundy for me. I'd prob be 6 beers in and still on one side of the truck.
    Taco Egghead and MGMDesertTaco like this.
  13. Oct 8, 2024 at 1:07 PM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    How much is your time worth to you? Sounds like the $600 was worth your time.
  14. Oct 8, 2024 at 1:12 PM
    MrGooch
    2021 Black TRD Pro
    You must not have a lot of close friends.
  15. Oct 8, 2024 at 1:25 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Price is not outrageous for the work you described. To a shop, customer supplied parts or not, it still takes the same amount of time in the bay.
  16. Oct 8, 2024 at 1:28 PM
    MrGooch
    2021 Black TRD Pro
    fair enough, but I called around 2 different shops were all between 5-600 for the work so....
  17. Oct 8, 2024 at 1:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Guess you should have gone there then
  18. Oct 8, 2024 at 1:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Watch a video on how to adjust rear drums, it's crazy easy.
    You could even buy a hardware kit at Napa for cheap and replace yourself (not that you'd need to this early).
    Replacing front rotors and pads is a simple job; I found one of those cheap caliper spread tools to be really useful for inserting new pads.
    Worst case, you'd need a second person to help you bleed your brakes when you run the old fluid out to replace with the new stuff.
  19. Oct 8, 2024 at 1:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Too late.....
  20. Oct 8, 2024 at 1:51 PM
    2021SR5V64WD
    I think brakes are the most important feature of anything you drive, I'd never trust myself to do a brake job myself.
    I reckon at 25,000 miles my 2021 has another few years before I'll have to deal with that.
    HondaGM likes this.
