Has my 157,000 mile 2009 TRD Off Road had an abnormal amount of failures?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Sep 13, 2025 at 7:47 AM.
  1. Sep 13, 2025 at 11:17 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    you got a lift and big wheels/tires?
  2. Sep 13, 2025 at 11:32 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    This doesn't strike me as awful for basically 17 yrs. I'm a 2 wheel drive but 2010 with just under 150k. Haven't had to do much up front, but it did need sway bar pins. I did run into the intermediate shaft about 2 yrs ago.
    I did have a run in 2023 that cost me about 4k in all, mostly expected items. Exhaust for instance..battery/alternator. The oil pan croaked but it wasn't a horrible cost as the 2WD is easier.
    Ultimately you have knowledge and confidence in the truck which is priceless.
    Hell, I had a Colorado 4wd before this truck and that was a piece. All new U joints at 30K..a few of the cam solenoids..some other stuff I forget. Cylinder head failure and the timing chain as well.
  3. Sep 13, 2025 at 5:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    For reference MY 2007 has 260,000 miles. So far, I've replaced
    HVAC fan at about 125,000
    Alternator at 170,000
    One U-Joint at about 170,000
    I've spent more in the last 1 1/2 years. New starter at 255,000
    New CV axles at the same time.
    Replaced the factory coolant and hoses as well as new plugs at 245,000
    Front brakes 2-3 times, I don't remember. Rear brakes at 200,000. I still have factory rotors and drums.
    It's on the 3rd battery.
    Serpentine belt every 100,000 miles.
    I've had 265/75/16 tires on it since the factory tires wore out. 2' lift for about the last 60,000 miles.
    I don't change transmission fluid, ever. Not in any vehicle in 50 years of driving. Never had an issue.
    I changed the oil every 10,000 miles or 6 months for the 1st 9 years and 180,000 miles. It's driven less now so I just do it every 6 months which works out to 5000-6000 miles.
    StihlToyota likes this.
  4. Sep 13, 2025 at 6:47 PM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Negative. The truck is 100% stock.
  5. Sep 13, 2025 at 6:49 PM
    Plasmech
    You're doing a lot better than I am.
    I would have expected 250,000 miles out of a Toyota, any Toyota, before having to wrench on *any* non-wear item.
    I'm not going to lie: I'm disappointed.
    Yes, PA is technically a "salt" state, but it just doesn't snow like it used to. We can go several years with next to no measurable snow. It's not like it was when I was in my teens and 20's.
    So why did this happen, I wonder?
  6. Sep 13, 2025 at 6:59 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’ll give you
  7. Sep 13, 2025 at 7:05 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Still better than the competition in my opinion, still better than a car payment
    If it was a Chevy it would be on its 3rd transmission and the rear main seal would be leaking a quart every 500 miles
    Dm93 likes this.
  8. Sep 13, 2025 at 7:08 PM
    Plasmech
    ...and arguably still better than the abysmal build quality of the Gen 4.
  9. Sep 13, 2025 at 7:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Notice how nothing you mentioned is an internal engine or transmission problem?
    Every fricken week we see Jeep/Chrysler vehicles with Stellantis engine problems. Blown head gaskets, valve-train problems..
    GM V8s with cylinder deactivation issues, the lifters and camshaft distributing metal shavings through the motor..
    Steves104x4 and Dm93 like this.
  10. Sep 13, 2025 at 7:29 PM
    Plasmech
    My engine and tranny are both tip-top. They’re not showing any signs whatsoever of going anytime soon.
    *knock on wood*
    b_r_o[QUOTED] likes this.
  11. Sep 13, 2025 at 7:48 PM
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    99% Stock: OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer). TRD Pro Grille insert, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    Re: "longevity lemon"?: IMO: No. Those are normal wear items you listed above (again: IMO) with the exception of maybe the transfer case, and perhaps the condenser. Just the pure age of the parts is a factor. At 16 years, those parts and others are simply getting old as well; regardless of the miles. Time takes a toll.
    FWIW, my 2012 has 144,000 (purchased with 104,000) and still has all of the original original parts and items on your list. Go figure.
  12. Sep 13, 2025 at 10:16 PM
    ABA180
    East Bridgewater MA
    That is a good point, I commented to a friend 2 yrs ago when in the midst of the expensive year I mentioned earlier that I'm at a point where some of the repairs mine will need are just due to age versus being a mileage based thing.
  13. Sep 14, 2025 at 6:06 AM
    Williston
    I'm also not sure that making a comparison of a first gen Tacoma to a second gen as I did is really fair here. I would assume Toyota took notice of any chronic weak spots on the 1st gen trucks (wheel bearings, u-joints, carrier bearing) and improved them, although the center carrier was still a problem. As a new offering for the U.S., I'm sure they were trying to keep the costs down too and spent their time and money on the bullet-proof 4-banger and the transmissions.
  14. Sep 14, 2025 at 10:29 AM
    ABA180
    East Bridgewater MA
    You'd think/hope so to be sure, but seeing as frames are still a thing..haha
  15. Sep 14, 2025 at 2:09 PM
    #35
    Williston
    I seemed to have lucked out and got one of trucks with a good frame. Minimal rust on the surfaces and edges and the laminated areas are good and treated with the off-white goop by the dealer. It has now passed four frame inspections by them. However the trailer hitch sheds paint even though I have scraped it and put about three new coats of paint on it, and Fluid-Filmed it at least three times with the rest of the frame. The spare tire mechanism and hoist gizmo also seems to form flaky rust on the surfaces just by lowering the tire and looking them over. :eek:
  16. Sep 14, 2025 at 2:15 PM
    #36
    ABA180
    East Bridgewater MA
    Mine got the black coating treatment on the first inspection, which I know they used prior to the white stuff you mentioned. Not sure why the move, but in my case it didn't help ultimately. The new frame has been solid so far, and I get it Woolwaxed yearly
  17. Sep 15, 2025 at 12:43 AM
    #37
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    We live in the same area and my truck has around the same mileage as yours.
    I haven’t had any mechanical failures minus my AC compressor clutch, but that’s it. My truck did come from Virginia Beach area, and I’m the second owner, bought it at 112K around 6 years ago.
    That said I did just put a lift on it with heavier tires and wheels, along with a steel bumper so I’m probably going to start breaking shit now lol.
    You’ve had more things break than what I’ve seen on this forum for being a stock truck. Seems unusual to me.
    You’re right, we barely get any decent amount of snow anymore, things have definitely changed compared to 20+ years ago.
    Plasmech[OP] likes this.
  18. Sep 15, 2025 at 3:29 AM
    #38
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    ^this
    It's not just about mileage, age gets a vote too.
