Has Toyota removed features without telling us?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AR15xAR10, Nov 22, 2013.
Did Toyota remove something you liked/loved when you upgraded to a newer model?
Poll closed Dec 22, 2013.
  1. Yes (explain in post if you wish).
    23 vote(s)
    47.9%
  2. No, not really....I was pretty content with the upgrades.
    6 vote(s)
    12.5%
  3. I was happy with everything.
    8 vote(s)
    16.7%
  4. I'm indifferent, its a truck i drive.
    11 vote(s)
    22.9%
  1. Feb 15, 2014 at 5:51 PM
    #81
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    If the harness is there, that's means the wires should already be run. The harness is the wires. Should just need to plug in the overhead unit, and potentially get an ambient temp sensor if it's not there. That would be cool
  2. Feb 15, 2014 at 5:52 PM
    #82
    AR15xAR10
    AR15xAR10 [OP] AR10 is 5 ARs better
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I'm pretty sure that is all it will entail other than ditching the stock mirror
    Tractorman likes this.
  3. Feb 15, 2014 at 6:05 PM
    #83
    Spoonman
    Jamie
    Alberta
    My stock mirror I would keep, Its got the compass on it
  4. Feb 15, 2014 at 6:10 PM
    #84
    keninsb
    keninsb "Senior", Senior Member
    Ken
    Goleta, CA
    '13 Taco DC 4WD V6 LTD
    That is very cool. Glad it worked out for him.
    A MUCH cheaper option for you is to get an Ultra Gauge. It displays Outside Ambient Air Temperature and you can set it up to display up to 8 parameters at a time. A LOT cheaper than the mirror, but does not have the compass.
    Ken
  5. Feb 15, 2014 at 6:15 PM
    #85
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I bet it only displays intake air temp, which is pretty much outside air temp while you are driving, it being a factory CAI and all.
  6. Feb 15, 2014 at 6:17 PM
    #86
    Spoonman
    Jamie
    Alberta
    Only thing is I don't like the look of aftermarket units like that. Otherwise that's a sweet idea
  7. Feb 15, 2014 at 6:31 PM
    #87
    keninsb
    Ken
    Goleta, CA
    I believe that IAT is a different parameter. I have attached the Ultra Gauge Manual and it lists all of the parameters and their definitions, they are listed as two separate parameters.
    Ken
  8. Feb 15, 2014 at 6:38 PM
    #88
    AEmedic
    AEmedic Well-Known Member
    Boise, ID
    2014 DCLB 4X4 TRD Sport Supercharged
    TRD Supercharger, Toytec Adj. Coil-Overs, Bilstein 5100's, JL Audio system w/Kenwood DNX9980HD HU
    My Ultra Gauge does not display the outside temp, it is not an option on the menu...believe me, I looked!
  9. Feb 15, 2014 at 6:41 PM
    #89
    AR15xAR10
    He is saying intake air temp is almost as close as outside temp...i'll have to check because i think it'd be a little higher
  10. Feb 15, 2014 at 7:06 PM
    #90
    keninsb
    Ken
    Goleta, CA
    You are right! Crap! If you look at the table of contents it shows "Intake Air Temp" as one parameter displayed and "Outside Ambient Air Temperature (ÂşF)" as another separate parameter. I just checked my UG on my truck and sure enough outside temp was NOT a selectable parameter. I think that the manual shows all the possible parameters that may be displayed IF the vehicle supports it. Sorry about that guys:(
    Ken
    Time for me to step away from the laptop before I do some real damage...
  11. Feb 15, 2014 at 7:27 PM
    #91
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    It does give a general idea though. The IAT is in the MAF sensor so it's about 5-10 degrees higher than ambient when going down the road.
  12. Feb 15, 2014 at 8:57 PM
    #92
    worthywads
    It's spot on or 1-2F higher on mine on the way to work, no where near 5-10 unless I'm sitting at an intersection then it might rise 5F temporarily.
  13. Feb 15, 2014 at 8:59 PM
    #93
    worthywads
    If the vehicle doesn't have an ambient temp probe there is no way it can have that as a selectable parameter of course.
  14. Feb 16, 2014 at 6:10 AM
    #94
    AEmedic
    Boise, ID
    That is the interesting thing, our trucks do have an ambient temp sensor. It is on the center radiator support behind the grille, but the truck only uses it for the A/C temp differential, or so I have read...
  15. Feb 16, 2014 at 6:27 AM
    #95
    dansmith1984
    dansmith1984 New Member
    Dan
    Central IL
    2014 DC TRD Sport MGM
    I went from 07 Tundra Limted CrewMax to 14 Tacoma DC TRD Sport - came with basic mirror. Only thing about mirrors between trucks I missed was auto dimming and homelink. After reading thread on here determined the tacoma was prewired and I ordered a homelink auto dimming compass mirror for about $170 from the main guy on here. Literally a 10 min install for the new mirror and I love it! Sold base mirror on eBay for $15 just to help somebody out vs pitching it
    #95
  16. Feb 16, 2014 at 7:40 AM
    #96
    AR15xAR10
    Thats awesome. Glad it worked out for you! I love seeing tundra owners convert to tacos :D
    #96
  17. Feb 16, 2014 at 11:01 AM
    #97
    mrzip
    mrzip Well-Known Member
    USA
    2023 Off Road, 2010 Off Road
    I have to go along with this. If Ford brings back the Ranger or something comparable to it I will probally jump back to Ford.
  18. Feb 16, 2014 at 11:26 AM
    #98
    AR15xAR10
    I'd love to see a new ranger but they make more money on te F series and will probably never go back to midsize in this country :(
  19. May 9, 2014 at 6:10 PM
    #99
    Toiyabe
    Toiyabe Active Member
    Maryland
    01 TRD
    Best quote ever.
    I love people who have no idea what they're talking about.
  20. May 10, 2014 at 7:45 AM
    #100
    Gusteru
    Gusteru Member
    West Canadian Coast
    2014 TRD Off-Road Access Cab
    Hi Dansmith! Do you have temperature display also, on that mirror? My 2014 Off-Road is missing this feature (false advertising), and I would really like to have it. I do have homelink auto dimming compass mirror on this truck, without temperature.
    Thanks!
