Hauled a bunch of sand in my bed. Best way to clean out the hinges?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willd0ugh, Sep 1, 2021.
  1. Sep 1, 2021 at 6:05 AM
    willd0ugh
    willd0ugh [OP] Well-Known Member
    2020 Cement TRD OR DCSB
    Noticed that when I’m pulling on the handle to open the tail gate it’s quite sticky. I’m gona clean the bed today with a pressure washer and worried I’ll blast away any grease or lubricant that’s in the joints and such
    anyone have any tips on how to properly clean out all the sand that’s settled in all the mechanisms without damaging it. And also any recommendations on what I need to relubricate with if that’s necessary thanks!
  2. Sep 1, 2021 at 6:07 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    soap and water by hand. If it's still sticky/gritty use WD40 to clean it more. Once you get it unsticky, re-lubricate with a white lithium grease. Don't use a pressure washer. Use a hose.
  3. Sep 1, 2021 at 6:10 AM
    alexn1018
    alexn1018 Active Member
    Alex
    Roanoke, VA
    2018 White TRD Off Road Double Cab
    You might try compressed air for the hinge areas before you get anything wet so get rid of the loose sand.
    pltommyo likes this.
  4. Sep 1, 2021 at 6:13 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yeah, I would blow out what you can with some compressed air before doing anything with liquids.
  5. Sep 1, 2021 at 6:16 AM
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    Once you clean it - TEST IT BEFORE CLOSING IT!
    Click the latches on both sides shut by hand, then try the latch handle. If it works a few times, great. If not - it's easy to get the panel off to fix it while still open. If you close it and it sticks shut, getting the panel off is hard and fixing it is hard. Trust me.
  6. Sep 1, 2021 at 6:16 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Look, nobody is going to judge you for buying a second hand Toyota from the Taliban. No need to make up stories about hauling sand.
  7. Sep 1, 2021 at 6:19 AM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Are you talking about the handle or the hinges? I would not lubricate the hinges as any grease would actually attract dirt. I'd just blow it out with an air compressor. You could grease the handle after cleaning if that's your concern.
  8. Sep 1, 2021 at 6:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Lawfarin likes this.
  9. Sep 1, 2021 at 6:53 AM
    willd0ugh
    Sounds like a good excuse to finally get myself a compressor for the garage. Yea the sand I hauled was alittle wet. I imagine once it dries and I hit it with air it would work out. Thanks!
    alexn1018[QUOTED] likes this.
